Two Questions about 05 CTD
Old Oct 24, 2005 | 07:30 PM
amcjerk's Avatar
Ok first how come my 05 didnt come with a block heater ? How much is one from the dealer ? Second the cold weather TSB for low cab heat or high idle , can only a dealer do this or can I ?I dont want to take my truck in to the dealer cause I'll have to take off my edge . I want the high idle cause I will be making alot of stops this winter and I would rather leave my truck running .
Thanks
Mike
2005 3500 4x4 DRW edge W/juice
Old Oct 24, 2005 | 07:45 PM
Herrin811's Avatar
as far as I know, ALL Cummins come with the block heater, but Dodge made the cord to use it an option
And yes you must have a dealer enable high idle
Old Oct 24, 2005 | 08:31 PM
jay05torque's Avatar
i bought a heater cord from genos..and i thought i read or heard, the truck will high idle automatically if under a certain degree (temp). a senser in the air duct??
Old Oct 24, 2005 | 08:55 PM
HorseHauler's Avatar
2003 and early 04 trucks would go into high idle mode below like 38*F or somthing around that temp. the 04.5+ trucks can get the high idle enabled to be used through the cruise control buttons, keep in mind this is only for automatics.
yes your truck has the heater in it, you just need to buy the cord if it already did not come with it. i suggest not buying it from the dealer, they want close to $40 for it when you can get the same thing at cummins or other places for $12
Old Oct 24, 2005 | 09:06 PM
rjm022's Avatar
my 04.5 will automatically raise its idle when the temp gets low enough. ( on cold mornings). but i also have the high idle feature enabled. which allows me to do the samething , anytime i want - using my cruise control "on" button and my "accel" button.
Old Oct 24, 2005 | 09:46 PM
Equalizer 2's Avatar
I also have the 04.5 but with the manual tranny. It also goes to high idle when the temp is could enough.
Old Oct 24, 2005 | 10:15 PM
ok so they must have kept that feature but also able to enable the cruise control feature... either way i like it
Old Oct 25, 2005 | 07:36 AM
amcjerk's Avatar
Where does the cord plug into ?
Old Oct 25, 2005 | 09:28 AM
DmaxEter's Avatar
On the block just behind the oil filter. I Might have an extra cord in new and unused condition if someone needs one. Its been on my truck but never used. I got a cord from work with a recepticle with a cover over it to keep the plug out of the elements.
Old Oct 26, 2005 | 12:03 AM
J BODY's Avatar
Boy oh boy we could have had some fun with this one!
....actually the heater element should have a cap on it that you can unscrew and then install your cord. DmaxEtr's location description should get you there.
outside304
Jun 12, 2010 06:14 PM
Totallyrad
May 23, 2010 12:42 PM
dieselcarpenter
Nov 17, 2007 07:02 PM
crobtex
Oct 15, 2006 09:59 PM
Dieseldude4x4
Jan 4, 2003 03:07 PM
