turbo fin question
Old Sep 3, 2004 | 11:14 PM
Jmac's Avatar
Unhappy turbo fin question
Upon removing the silencer ring I wound up scratching 3 of the turbo fins... Although not bad as scratches go.. Is this bad ? what are the effects of this?
thanks
Jamie
Old Sep 3, 2004 | 11:57 PM
Whitmore's Avatar
as long as they arent deep as it would change the balance, the paint you see on one of the blades is for balance, this turbo spins 24,000rpm so balance is critical
Cheers, Kevin
Old Sep 4, 2004 | 02:59 AM
jkitterman's Avatar
The scratches will be the weak points in the fins and may stress fracture now. A lot will depend on how you scratched or nicked the fins.
Old Sep 4, 2004 | 08:05 AM
hoot's Avatar
I think the turbo hits 100,000 rpm
Old Sep 4, 2004 | 08:38 AM
Whitmore's Avatar
, I thought I read 24k somewhere??? 100k is way fast
Cheers, Kevin
Old Sep 4, 2004 | 11:48 AM
Jmac's Avatar
Nicked is a better word , just enough to remove the dirt on them and make a mark.
Should I replace it with a new one.
Jamie
Old Sep 4, 2004 | 11:59 AM
joel's Avatar
Sounds like a good excuse to bomb your turbo.... maybe get one of those twin turbo setups.....
Old Sep 5, 2004 | 10:57 AM
nickleinonen's Avatar
Cheers, Kevin
the little hy might be toping somwhere along the 120k rpm range at full boost, and if you blip the throttle downshifting, you might get a little more rpm out of it as the pressures on both sides are balanced... heck, at work, on them 2 cycle emd diesels with a compressor wheel coming close to 12", they turn about 18-19k at full tilt
Old Sep 5, 2004 | 12:15 PM
Smkndzl's Avatar
Turbo RPM with the EGR motor were running these days we can monitor the rpm with insite , other day I was running the ISX on the dyno making about 35 pounds of boost and turbo rpm were around 94,000 . hope that answer your rpm question.
yarddog
Jun 30, 2006 09:50 PM
Brock
Jan 17, 2006 08:45 AM
kully560
17
Aug 18, 2005 03:14 AM
jrs_dodge_diesel
Oct 16, 2004 06:14 PM
fanofthewolf
Mar 3, 2004 09:18 AM
