trying to discover a vibration
Old Jul 14, 2009 | 11:34 PM
Catmandoram's Avatar
Good point. Yes, it was done on a RFB. They're saying it's not the tires because of that.
I'm going to change my drive line u-joints and see if that works.
Thank you.
Old Jul 16, 2009 | 12:59 AM
bgott's Avatar
You said you had 3000 miles on new tires. Did it do it on the old tires?
Old Jul 16, 2009 | 10:33 AM
fl dodge's Avatar
i had the same thing going on with my truck . i took both front and rear drive-shafts and had them balanced ,both of them was out when i reinstalled them it helped alot,just something you might want to consider
Old Jul 16, 2009 | 10:52 AM
Fiftygrit's Avatar
I had khumo tires they were balanced 4 times and still shook, I went to michilens and they are so smooth, no shaking at all, sure made a big differance, good luck
Old Jul 16, 2009 | 04:37 PM
It shook but I had bad Ball joints and ate the tires sooooo I can't say where it was coming from
Old Jul 16, 2009 | 04:40 PM
Good Ponit. Where does one go to have that done? Machine shop?
I just replaced all the drive lines u-joints. Might of help a little, but still there. Just took the truck back in to the tire shop and had them rebalance agian. Right now no more shakes. I'm really thinking this is my last set of BGF's Nothing but problems!!!
Old Jul 16, 2009 | 04:41 PM
I'm wishing I did that!
Old Jul 22, 2009 | 11:40 PM
FOUND THE PROBLEM! After changing all the U-Joints. I had the tires rebalanced and Wham!!! Perfit!!! Thanks to all for your help.
ColinP
Feb 11, 2012 04:58 PM
mikmaze
Aug 30, 2009 07:09 PM
tywebb3
13
Nov 20, 2008 12:06 PM
tcr
16
Jul 21, 2007 01:08 PM
Tomtt
Aug 25, 2005 08:27 PM
