Truck shuts down
Old Jul 27, 2011 | 11:01 PM
exwrestler's Avatar
Truck shuts down
Lately in the morning when I go to start my truck it runs for 10 seconds and dies. Also noticed security light blinks and temp light comes on. Now tonight I was driving down the road and check gauges light came on temp light came on truck chimer went off all gauges went to zero like the the truck was not running but it was. I jiggled the key in the ignition and all the gauges came back on and then off again and then it was fine. Has anyone had this trouble and if so what is going on?
Thanks
Old Jul 28, 2011 | 11:42 AM
luke03cr's Avatar
It sounds to me like you have an ignition switch problem. Those are the symptoms usally associated with an ignition switch going out
Old Jul 28, 2011 | 11:46 AM
cbrahs's Avatar
not a switch problem. sentry problem. get all keys re-programmed. its not recognizing the key you use. try another key. if you decide to get it reprogrammed, keep in mind you must bring ALL keys you have or the one (s) you left at home WILL NOT WORK AT ALL
mopar65pa
Jul 12, 2008 06:40 PM
HIGHGEAR
Dec 17, 2007 12:34 PM
mowin4dodge
Sep 22, 2006 08:46 PM
Txwelder
Oct 9, 2005 08:09 AM
