Transmission problem
Old Feb 26, 2017 | 11:36 AM
corona extra's Avatar
2006 dodge ram 2500 5.9 RWD 48RE Just changed my pressure sensor selinoid and transducer, and my p1749 went away. But now it won't shift right away to 4th and OD, it hangs on there for lil while. Any solutions. Have 15000 miles on it, never tow use as daily driver.
Old Feb 26, 2017 | 02:25 PM
johnh's Avatar
15000 miles isn't very much ,you need to drive it more to get it loosened up and broke in!
Old Feb 26, 2017 | 02:32 PM
2006 dodge ram 2500 5.9 rwd Transmission problem
I meant 150000 just had a reman engine install due to bad ECM.
Old Apr 20, 2017 | 06:59 PM
Man Grain's Avatar
have you figured out the issue also happening to my truck
Old Apr 20, 2017 | 10:19 PM
Found the problem
I did found the problem, I took it to the trans shop, and my buddy told me the trans was good , that he found a short on the wiring from the ECM to the trans. It did cost me $750 but it's a lot better then 2500.00 he replaced the throttle body unit with a new pressure selinoid and it's running good now.
Dauntless
15
Aug 30, 2016 08:37 PM
TGCTD
Jun 25, 2004 09:47 PM
dogman
Dec 27, 2003 07:06 PM
jec3
Jun 9, 2003 01:35 PM
NWDave
Nov 24, 2002 09:25 PM
