Transmission problem?
Old Apr 26, 2013 | 01:44 PM
Clbgbbn6's Avatar
Exclamation Transmission problem?
Recently I have noticed a shaking in my truck, the catch is that is only happens when the truck is cold. It starts shaking at highway speeds, 45 and up. At first I thought it was a unbalanced tire but then I realized that it has kind of a rhythm shake. As It was shaking I popped the transfer case into neutral and the shaking stopped, but the transfer case shifter was shaking horribly. When the truck warms up (10-15 minutes of driving) it stops and drives normally.
I am stuck and am sick of paying hundreds of dollars for a mechanic to tell me what I already know and replace some sort of sensor. So I joined a forum and hoping that I can save my self a couple trips to various shops.
Note: 5.9 HO diesel, 4 speed w/OD, and 4x4 transfer case. Also the front drive shaft recently sheared off. Thats when the shaking started. I have been ensured it was not that, but I'm not sure. It hasn't replaced it yet.
Old Apr 26, 2013 | 10:56 PM
47Dodge's Avatar
Maybe a stiff U joint? You put the T Case into N as you were moving down the road or at idle?
47
Old Apr 27, 2013 | 12:29 AM
Clbgbbn6's Avatar
47
Big O tires replaced the u-joints and told me that would fix it. And yes, even though I probably shouldn't have, I popped it into neutral and it fixed the body shakes, but the shifter was still shaking. The transmission was also in neutral.
Old Apr 27, 2013 | 01:01 AM
47Dodge's Avatar
If you have a 2 piece drive shaft it could be out of phase. I know older trucks would shake if the shafts are out of phase. Dont know if thats still true on the new trucks.
Its got to be drive line related I would think since it goes away when you kick the t case into N yet the shifter shakes. I would think from the T case forward to the engine is ok.
47
Old Apr 27, 2013 | 09:04 PM
vangasman's Avatar
You said you sheared off the front drive shaft and that's when it started. Maybe it bent something (yoke, etc). That's where i'd start. What were you doing to break the drive line?
Old Apr 29, 2013 | 10:05 PM
Clbgbbn6's Avatar
I got stuck in the snow and popped it in 4wd. Next thing I heart was a couple of smacks and that's when I noticed it was sheared. I was throwin it in and out if drive and reverse.
Dauntless
15
Aug 30, 2016 08:37 PM
TGCTD
Jun 25, 2004 09:47 PM
dogman
Dec 27, 2003 07:06 PM
jec3
Jun 9, 2003 01:35 PM
NWDave
Nov 24, 2002 09:25 PM
