transmission fluid capacity
Old Oct 21, 2010 | 11:43 AM
Hankpac's Avatar
I have a Dodge 2500, 2006 5.9, with Auto trans.
The manual does not show the capacity of trans fluid.
I did a search of the forum, but didn't come up with that particular number.
Anyone know?
Old Oct 21, 2010 | 12:24 PM
NavyDood's Avatar
Pan drop, filter change, and refill is 4qts according to the FSM. Get 6 qts to be safe though. It has always taken me more than 4qts.
If it's a rebuild and tranny is dry, then anywhere from 14.5 qts to 16.5 qts.
Old Oct 21, 2010 | 01:53 PM
pdogg's Avatar
I just did a pan drain and refill this past weekend, was about 4.5 qts.. luckily I installed a drain plug on the previous service..
Old Oct 22, 2010 | 10:00 PM
BigIron70's Avatar
Cummins Guru
68RFE - Service Fill 6.5 qts
Check in neutral level ground engine at operating temp.
LockedandLoaded
Jan 17, 2008 02:51 PM
johnr9q
Apr 8, 2006 12:18 PM
ouchman
Feb 25, 2006 11:22 AM
orcaburger
Oct 5, 2003 08:40 PM
BuckBoardDriver
Jul 3, 2003 07:30 AM
