transmission fluid
Old Nov 10, 2008 | 03:00 AM
itr.#1446's Avatar
transmission fluid
I am going to be some servicing to my trans soon and was wondering whats the best stuff to put back in? Are synthetics like amsoil good but then i would need to flush everything out for this correct and if i was to do it this myself where you disconnect the trans cooler how many quarts would i need?
Or is it better to just replace the fluid you took out of the pan when dropped?
Old Nov 10, 2008 | 04:34 AM
06RAM2500's Avatar
Fluid has to be compatible with ATF+4. Mopars is already a full synthetic, pick it up at Wal-Mart, about half what the dealer charges. All you need to do is drop/ clean the pan and magnet, change the filter, and adjust the bands. I never serviced the transmission, always had the dealer do it, so I couldn't tell you how to adjust the bands. Maybe search on it.
Old Nov 10, 2008 | 01:22 PM
CrashCade's Avatar
Here is a link on how to adjust the bands.
http://www.dodgeram.org/tech/transmi...T_band_adj.htm
Old Nov 10, 2008 | 01:44 PM
DBLR's Avatar
06RAM2500,
Mopar ATF is not full synthetic its made form group III crude oil.
itr.#1446,
If a person wants to use Amsoil synthetic ATF they don't need to flush out all of the old fluid, I know as when I did mine I just replaced the filter and refilled with Amsoil and have not had any problems in over 20K. FYI to just replace the filter and refill you will need around 6-7 qt's of ATF.
Old Nov 10, 2008 | 01:50 PM
Mlucas's Avatar
amsoils website says that the 48re has a 17quart capacity.-so if you only dump in 6-7quarts of amsoil-wouldn't you be diluting the good stuff quite a bit?
Old Nov 10, 2008 | 04:14 PM
itr.#1446's Avatar
that's what i am curious if i should just flush the whole thing and add synthetic but at the same time i don't have a lot of money to be spending so i might just keep mopar stuff in there until the i can afford to flush the whole thing with synthetic.
i am changing the filter while i am in there and thank you for the link
Old Nov 10, 2008 | 04:42 PM
SOhappy's Avatar
I'd keep ATF+4 in it, especially if you're still in the 7-70 powertrain warranty period.
Old Nov 10, 2008 | 05:34 PM
06RAM2500's Avatar
Most shops don't recommend doing a flush as it stirs up all the junk inside the transmission. You only need to drop the pan and replace the filter, fluid and clean the pan.
Old Nov 11, 2008 | 12:08 AM
RedRacer44's Avatar
When I switched to Amsoil ATF...we just dropped the pan, changed the filter, adjusted the bands, and refilled with about 8 quarts of fluid. Very simple procedure and no issues with just dropping pan and refilling...
Old Nov 11, 2008 | 12:10 AM
itr.#1446's Avatar
that is a good point i bought my truck used so i bought a 7/100k miles warranty
Old Nov 11, 2008 | 12:17 AM
itr.#1446's Avatar
when are you guys getting the 1-2 hunt when driving and it tries to shift to second or when at very low speeds. Also if i was to bring my truck to dodge for the tsb would they do it no questions asked even if i didn't have the problem yet?
Old Nov 11, 2008 | 12:14 PM
supersonictoys's Avatar
(Quote) Mopar ATF is not full synthetic its made from group III crude oil. (quote)
that is not correct. I have a bottle of Mopar atf+4 in my hand and it clearly states on the label that it is "fully synthetic". if it had any petroleum products in it, it would say "synthetic blend". $4.64 at wallmart. they also have "supertech" atf+4 which is also fully synthetic for $3.77 which is probably also just fine but for the extra 90cents a quart I figured I would rather the peace of mind of knowing I'm not installing cheapy swill fluid in my 40K truck
Old Nov 11, 2008 | 01:45 PM
SOhappy's Avatar
Agreed, but...
...you can do a "fluid exchange" without stirring up the junk. Just remove the rear tranny line, start the engine long enough to let it fill a gallon jug, add a fresh 4qts to the tranny, repeat 4x.
That's what I did for my 60k service. Good as new!
Old Nov 11, 2008 | 05:39 PM
itr.#1446's Avatar
I think i will try this way .....whats size hose should i buy 3/8? and how will i determine which line is the return? like where is the hose to the trans farther towards the front of the trans?
And whats the total amount of quarts i need?
Old Nov 11, 2008 | 05:55 PM
SOhappy's Avatar
I used a garden hose and a normal radiator clamp, the return line is the rear one, and you should get 17-18 qts but you'll probably use 16 (you can use the extra two for the transfer case).
Here's a write-up that works:
https://www.dieseltruckresource.com/...ghlight=tranny
Pretty much a piece of cake, just slow down, take your time and follow each step carefully (I nearly forgot to tighten my filter fasteners because I took a break to eat dinner).
