Transfer Case Shot @ 108,000
This sucks ! Have never abused the truck in 4 wheel drive. Are they just that weak ? Have owned a bunch of 4x4's ( first Dodge ) and never had issues.....
The stock fluid was also very dark.
I also flushed out the old fluid by draining out the old fluid and pouring through 2 quarts with the drain plug open, to flush out any contaminents or particles
Sounds like the chain is jumping sprocket teeth when under a load. Have not opened it up yet. Sound was so loud, I was worried parts might start flying through the case.
Shop says go with a rebulit one cause it has the 3 yr warranty rather than reworking mine. Total = $ 1,400 installed
What do yall think ?
( yes, fluid was changed as scheduled )
So the loud stripping teeth sound I heard this morning on my 2003 3500 dually when I put it under a load in 4 wheel is the chain shot?
Can you run it in two wheel drive or will parts start falling off?
I need to use the truck for the next three weeks but no 4x4
Thanks For the input!
Case model says 271 D
been running mine for the last two days with no problems. it makes no noise until 4x4 engaged. Mech said chain & sprocket, have not opened it up. From the sound, its probably a lot messed up.
couldn't be without the truck right now, so I have not open the case.
When I went through my tranny problems , the last place that worked on it drained the fluid out of my transfer case , and apparenty never filled it back up
....I never found that out untill ALMOST 1 YEAR later
I knew the truck had a driveline thump in it when I got it back , but no one would believe me , and tried to blame any noise I was hearing on the susp. lift/tires and wheels
Anyway , the last shop (friend of mine ownes it) willing to help me out decided to put it in the air and try 4WD , which I never really use lately , and it made all kinds of funny noises
. The tech. took a small bottle and was going to drain some of the fluid out into it. I told him he was about to get a bath in fluid , and much to our surprise NOTHING came out
I know for a FACT that no one had touched the transer case since the tranny was re-installed , so I contacted the shop. The were sceptical at first , but then said anything`s possible. They ended up replacing it with a used one I picked up for $350 from the recycling yard we use at work, and everything`s been fine ever since
Soooo, I`d say these things are pretty bullet proof
.I knew the truck had a driveline thump in it when I got it back , but no one would believe me , and tried to blame any noise I was hearing on the susp. lift/tires and wheels
BRUISER
Aug 16, 2006 11:14 AM
J BODY
20
Jun 4, 2006 01:32 PM
darom
Jun 28, 2005 08:13 PM
