Trans Temp & Tow/Haul lights flashing
Old Oct 22, 2008 | 07:40 PM
tands1000's Avatar
My truck has started goin in and out of O/D at about 65 mph and above. The tow/haul light keeps flashing and the trans temp does occasionally. I have done some searching and it appears that some have had this problem and was just wanting to double check on the transmission governor pressure transducer. Has that ultimately been the fix for everyone with the problem. Thanks
Old Oct 23, 2008 | 07:28 PM
ratlratl's Avatar
MMMmmmm.... Grits!!
Does sound like the transducer. It does serve as the pressure sensor and temp sensor as well. That would explain the Trans Temp light, but is it actually shifting down to third or is it just dropping out of lock up? If you do go into, go ahead and do the solenoid as well.
Chris
Old Oct 23, 2008 | 09:31 PM
jbone's Avatar
A buddy of mine had the same problem. He spent over a thousand bucks at Dodge, but they couldn,t fix it. He replaced the transducer-problem solved! Good luck
RepairBill
16
Jun 30, 2019 10:28 PM
mike wolfe
Nov 16, 2009 05:12 PM
RiverRat2
Jun 12, 2009 03:10 PM
MauleM5
Apr 30, 2009 07:04 AM
richard
Jan 4, 2006 09:37 PM
