abs & brake warning lights flashing
Old Sep 23, 2009 | 07:44 PM
mike wolfe's Avatar
I have a 2001 2500 4wd and the abs & brake warning lights are flashing anybody know what that means. thank you for any help
Old Oct 30, 2009 | 07:31 PM
pappyscrapster's Avatar
Could be a few things, I'm currently going throu this to, I've checked almost everything I can thing of, my next step is to remove my VSS (speed sensor) So yours could be one, or both of the following, electrical and or mechanical, start with the obvious, your fluids and fuses, then move into the connectors and sensors, when where your brakes last serviced? Hope that helps, if even a litte
Old Nov 2, 2009 | 07:20 AM
patdaly's Avatar
Flashing at all times or only when you step on the brake pedal?
Old Nov 2, 2009 | 09:10 AM
RowJ's Avatar
Since M.W. has not been back for over a month... let me ask this.
I got ABS/Brake lights (full time on) on Friday.
Replaced rear ABS/Speed sensor yesterday, as most often cause of this problem, but light have not gone out. Think I caught the problem as sensor was well coated with differential 'mud'.
Read in a thread that the lights won't go out till codes are cleared by a scanner?? True....or did I not fix the problem??
RJ
Old Nov 2, 2009 | 11:58 AM
patdaly's Avatar
Dunno about your 02, but on 97's at least when the problem is fixed the light goes out.
I would bet 02 is the same way.
Old Nov 2, 2009 | 12:05 PM
RowJ's Avatar
Had a scan done on a friends Snap-On Scanner. Showed no signal coming from Front Right Sensor.
So, on to next replacement.
During a search, I remember a post from 'Infidel' saying had to clear codes to eliminate ABS light. Not easy to catch him being incorrect....... but perhaps I misunderstood what he was saying. Believe he was talking about his 95??
RJ
Old Nov 2, 2009 | 01:57 PM
AggieJustin's Avatar
Check the plugs on the ABS module under the hood first.
I had a loose plug one time that was showing up as a no signal from a front sensor. Also caused full lockup on that wheel under hard braking. You can also pull the plugs and test the sensors with a ohm meter, but I'd have to look up the correct values for a good sensor.
Old Nov 2, 2009 | 02:21 PM
RowJ's Avatar
That was first thing I did...after checking brake fluid level. No such luck for a simple fix!
RJ
Old Nov 4, 2009 | 07:02 AM
RowJ's Avatar
I replaced the front sensor last night.
About 30 sec after third start, the ABS & Brake Lights went out!
I guess the computer takes a bit of comvincing before it decides all is OK!
RJ
Old Nov 5, 2009 | 11:30 AM
Hey guys, I still have no resolution on my brake/abs deal, nor can I figure out which is the speedometer sensor on the overdrive portion of my tranny even with pictures haha any help would be nice, thanks
Old Nov 5, 2009 | 09:17 PM
mwdean's Avatar
speedo function is from sensor in rear pumpkin
Old Nov 6, 2009 | 07:35 AM
RowJ's Avatar
Originally Posted by pappyscrapster
... nor can I figure out which is the speedometer sensor.....
Yup! On front top...dead center of pumpkin. Easiest one to replace. 10 min jobs (after you've done it once...)
This is from Field Service Manual......
REMOVAL of Rear ABS/Speed Sensor.....
(1) Raise vehicle on hoist.... optional
(2) Remove brake line mounting nut and remove the brake line from the sensor stud.
(3) Remove mounting stud from the sensor and shield (Fig. 6) .
(4) Remove sensor and shield from differential housing.
(5) Disconnect sensor wire harness and remove sensor.
Sensor just slides up and out...but not easily if it's never been removed before.
Hope this helps.
RJ
Old Nov 10, 2009 | 10:07 AM
............Ok, IDing that seems to be the problem, I've been told that my rig also has a speedometer sensor on the overdrive housing portion on the tranny, so your saying you think my truck has only 1 speed related sensor? I know of the pumpkin sensor.
Thanks for the input
Pappy
Old Nov 10, 2009 | 10:09 AM
Hope this helps.
RJ
Hahah I know that "after the first time deal" hahah it does help in the fact that I'm more confident about doing it, after hearing that someone has done it.
Thanks again
Old Nov 10, 2009 | 12:44 PM
RowJ's Avatar
Good Luck! probably took me an Hour. Most of that ws trying to figure a way to get to it from the front of the axle.
Ended up sitting on the ground behind it, with back of my head against the truck bed. (Best way, IMO .... if you don't have a spare underneath).
RJ
