Trans slipps when cold
Old May 14, 2007 | 05:50 PM
DJ's Avatar
DJ
Hi, I have a friend who bought an 06 CTD mega cab on my recomendation. At about 4000 miles he noticed that after sitting for several hours or overnight the trans would not engage for 3-6 seconds after putting it in drive. He can rev the engine all he wants and it won't move at all, then after a few seconds it starts working and is good the rest of the day. It sounds like the torque converter is leaking down like what happens when a trans gets real old and worn out. He has had it to two different dealers and both say it checks fine. What I'm wondering is has anyone else noticed this on their transmission, if so have you taken it to the dealer and if so what did they say?
Thanks
Dave
Old May 14, 2007 | 08:15 PM
kev94mx's Avatar
MINE IS THE SAME WAY. It will only get worse and the tranny will probably go next if you pull alot. I have herd that if you shift in neutral for a few seconds that will get the fluid going. I am not sure on this.
Old May 14, 2007 | 09:34 PM
Lost Lake's Avatar
Mine does it. I start it and put it in nuetral for 60 seconds before I go anywhere.
Old May 14, 2007 | 11:44 PM
StrokeThisCTD's Avatar
Just gotta pump some fluid in the tranny. You need to let the truck idle for around 20 seconds on the first start of the day to get fluid flowing. Some duramaxes wont go anywhere for a few minutes if its cold enough
Old May 15, 2007 | 10:26 AM
Raspy's Avatar
That's been a part of Dodge trannys since the '60s. Mine does it too. It does NOT mean the tranny is about to go out. The fluid just drains back after sitting a while. Annoying, but harmless.
Wetspirit
Old May 15, 2007 | 11:39 AM
MEGA COP's Avatar
Mine does it too and when I called the dealership about it he told me that there is a TSB on them for the filter falling down. The tech told me that several new trucks have been towed in with total trans failiurs because of this and that i should get it in to them ASAP. The clincher is the tech who I talked to is on vacation this whole week, and won't be back till next Mon. and he is the dealerships transmission guy. So I hope it holds together till next Mon.and that he can have it fixed by Memorial weekend (the following Fri.) so I can pull the boat up north for my vacation.
https://www.dieseltruckresource.com/...d.php?t=150576
Old May 15, 2007 | 01:00 PM
wreedCTD's Avatar
maybe this is what happened to you kev94?
Old May 15, 2007 | 01:02 PM
wreedCTD's Avatar
can someone post the TSB for the filter falling?
Old May 15, 2007 | 01:33 PM
Rob C's Avatar
If it is a TSB, it will be listed in here:
http://www.dodgeram.info/tsb/
Old May 15, 2007 | 05:54 PM
MEGA COP's Avatar
Looks like that is the one
http://www.dodgeram.info/tsb/2006/21-007-06.htm
Old May 15, 2007 | 06:07 PM
Raspy's Avatar
That TSB says it's for the 45RFE and the 545RFE.
Wetspirit
Old May 15, 2007 | 06:13 PM
MEGA COP's Avatar
Wetspirit
Your rite...now I'm really confused..based on what the tech told me. I don't think I have either one of those transmissions in my truck. I'm pretty sure it is the 48RE in mine.
Old May 15, 2007 | 06:46 PM
Raspy's Avatar
MEGA COP,
That tech must have been talking about a non CTD truck. As I said, slipping in the morning or after sitting is a common nuisance. Not an indication that it is about to blow. Maybe we are taking about two different things.
Wetspirit
Old May 15, 2007 | 08:05 PM
donhov's Avatar
And remember that the pump does not work in park, you must shift into neutral for the pump to start filling things and then it will/should be ok for the rest of the day while driving it.
Old May 26, 2007 | 11:08 PM
pilotofhelo's Avatar
Problem fixed
The Dodge dealer first tried replacing the trans cooler line check valve. That didn't imporve the problem. Then they pulled the trans and found that a plug from a pre-bored hole in the front pump case had fallen out. They replaced the front pump and it seems to be fixed. No more delay. Thanks for the help.
Hydrauk
16
May 7, 2008 02:58 PM
akhunter68
Oct 31, 2006 05:07 PM
joel
Jan 22, 2005 08:59 PM
BEHRMAN
Dec 24, 2004 11:05 PM
wings
Nov 8, 2004 05:32 PM
