trans service and what to upgrade
Old Oct 1, 2011 | 07:03 PM
kdavis80s's Avatar
got 05 need to service trans. plan on using amsoil unless someone else knows of a better fluid, also going to drill 1/4" and tap tc to beable to get all of trany fluid out. what can i do to upgrade the trans while having the pan off? I plan on running a smarty jr
Old Oct 2, 2011 | 09:30 AM
no_6_oh_no's Avatar
ATF+4 for fluid. Amsoil is overly expensive for the application. Since you need to change the fluid every 30k it just costs too much for the benefit. ATF+4 is as good as it gets with the OE build and is better than most.
Upgrades:
shift kit
billet band strut and anchor
billet front servo with better seals
billet accumulator with better seals
gov pressure transducer and solenoid (either the GM type or the OE upgrade solenoid)
Old Oct 2, 2011 | 09:49 AM
Fiftygrit's Avatar
I just used valvoline ATF+4 its synthetic and was around $4 a quart, with my double deep pan taking 24 quarts, I couldnt afford amsoil, like no 6 said every 30k miles.
Old Oct 2, 2011 | 04:38 PM
Rob's Red Ram's Avatar
Yikes I have 55000mi on mine and haven't serviced transmission yet.It's on the list b4 winter though, as I just had entire front end rebuilt new everything.
Old Oct 2, 2011 | 06:20 PM
kdavis80s's Avatar
Upgrades:
shift kit
thanks for the info, also where is the best place to buy these parts?
Old Oct 2, 2011 | 08:41 PM
no_6_oh_no's Avatar
This is a good a placer as any: http://www.transmissioncenter.net/dodge.htm
These parts can be obtained form most any trans hsop also but they may charge you more.
Old Oct 2, 2011 | 11:27 PM
1KhakiMegaCab's Avatar
Holy Cow there's a lot of info there at that site. I like it and will be doing some research for my transmission. Thanks for the link.
Old Oct 4, 2011 | 01:11 AM
.boB's Avatar
That doesn't sound like a good idea to me. In theory, a drain port would sure be nice. In reality, I don't think the meaterial is thick enough for that. I'd be willing to bet money that it will leak.
And, it will be out of balance unless you do the same thing 180* away.
Old Oct 4, 2011 | 09:47 PM
kdavis80s's Avatar
i do it to all my cars and trucks, plenty thick, never leaks when you use a tapered threaded plug, out of balance, nah the material you remove is about the same material and as an alen tapered threaded plug, its not very big
Old Oct 4, 2011 | 09:55 PM
kdavis80s's Avatar
also google it, "how to install drain plug in torque converter" its done all the time. also how much money did we bet?
steelblitzkrieg
Oct 14, 2011 09:19 PM
MegaTony06
0
Jul 22, 2011 01:06 PM
studio5o
16
Sep 17, 2010 06:35 PM
dieselbeef
Jun 12, 2006 08:12 AM
Lightman
35
Dec 2, 2004 08:34 PM
