Trans problem 48re
Old Mar 17, 2016 | 12:03 PM
Springer's Avatar
Trans problem 48re
Got the 1st to second hunt. Changed fluid about 10k ago. Truck has 116k with maybe 20% towing trailer under 10k.Tried the front band adjustment backed off the locking nut and got my inch pounds torque wrench . When I tried to adjust it was so loose it took a while for resistance went to 72 inch pounds backed off 1 3/4 turns . Started truck put it in reverse and it felt like the trans was binding . Wouldn't back up. Had to loosen the adjuster adjusted it again same thing. So I backed it off till it felt ok. Transmission time? Any advise would be helpfull
Old Mar 21, 2016 | 06:59 AM
PWong's Avatar
I would do the BW gov pressure solenoid and Mopar pressure transducer, adjust BOTH banks and see..............
Old Mar 24, 2016 | 02:11 PM
Springer's Avatar
I did the transducer and selonoi today. Shifts like it should again
Old May 5, 2016 | 05:29 PM
JonRAM2500's Avatar
Same issue with all 48RE trans..... A new Gov Pressure solenoid and transducer usually do the trick.... Glad yours is back up and running!
Old May 31, 2016 | 05:42 AM
WL.'s Avatar
WL.
Should be a stickie on this....
FYI, if you have a 48RE, replace both and keep going. Has anyone not had this issue??
nfsommer
Nov 9, 2007 09:36 AM
Patrick Campbell
Dec 13, 2003 05:38 PM
Sittenbull2
Apr 24, 2003 12:00 AM
bigbaddiesel
Jan 3, 2003 12:36 PM
FireNhole
Dec 7, 2002 04:39 PM
