Drive like clunk
Drive like clunk
05 six speed just installed caltracs to stop axel wrap I still get a ca chuk noise at city speed if you get on and of throttle quick. Already har one piece drive shaft. Pinion movement turning drive shaft is about 3/8 or so it's alway been about that. Any body have issues with trans mounts wearing out or getting loose.
Front driveshaft?
I pulled mine, it had play in the spline sections. I'm sure that doesn't help the clunk I get when I don't drive smooth on the Go pedal.
Sounds similar to a somewhat common problem I had and have again with the tranny mount bolts shearing. Happens to alot of manual trucks with g56 6sp and can be a number of causes from broken motor mount to cracked housing on the trans...search g56 trans mount.
Cummins610
17
May 29, 2010 12:50 AM
Bigwhitey3500
Jul 23, 2007 08:05 AM
MasseyMan1089
May 23, 2007 07:56 PM
Copenhagenjunkie
Dec 27, 2002 05:45 PM
