48RE Trans cooler
Old Dec 11, 2003 | 08:14 PM
Patrick Campbell's Avatar
48RE Trans cooler
Does my 2500 SO have the same trans cooling as a 3500 HO dually would have? Does it just go through the radiator or does it have an external one also? Any need to add a 2nd external one or replace the stock one with a larger one from B&M or FlexAlite or PermaCool if hauling heavy loads? If so, are there any that are "direct fit" ?
Old Dec 11, 2003 | 09:33 PM
Hairy1's Avatar
From: Adirondacks of New York and Daytona Beach FL.
Re:48RE Trans cooler
It has an external cooler.....Outside going towards engine 1st the airconditioner 2nd intercooler 3rd tranny cooler under it the power steering cooler then the radiator. It should have all it needs the way it is.
Old Dec 13, 2003 | 05:38 PM
henchman's Avatar
Yup. Your truck should be just fine. Get under it and follow the tranny lines. Mine goes into a heat exchanger first which puts heat from tranny fluid into the engine coolant. That is on the driver's side rear of the engine. Then the fluid goes into a huge cooler that the post above describes. so we all should have 2 tranny coolers. plenty
murfpcola
Sep 30, 2013 12:20 AM
nvr-enuf
May 10, 2011 02:49 PM
nfsommer
Nov 9, 2007 09:36 AM
EClancy
Jan 16, 2007 09:27 AM
live wire
Jul 21, 2003 07:26 AM
