Clutch Disc- TSB 06-001-03
An FYI for everybody:
I got my truck out of the shop last night. The dealer replaced the Clutch Disc according to TSB 06-001-03. I drove it home last night and back to work this am- no Rattle while idling in neutral with foot off clutch- thank goodness!! They appeared to have done a good job! Shifts great, pulls hard! I looked at the new clutch disc before they installed it- don't look like there is much to it. Looks like the "Rattling" was coming from the springs that are made into the clutch disc? Maybe this info will help somebody out there..in case this is a problem your having?
I also had them to replace one headlight- had moisture behind the lens. Maybe I'm ready to go now... Looking at a "Western Diesel Perfomance" box to bump up the HP and Torque???
Merry Christmas!
Merry Christmas!
Re:Clutch Disc- TSB 06-001-03
I had mine done a about 33,000 miles. Now at 47,000 it's just as bad as it ever was. It did go away for a little while though.
I wish mine would rattle, then I could have them put a South Bend in ;D
28,000 Miles and never had any rattle at all...... ???
Mine has rattled almost since the day it was new. Not going to do anything about it either. If the clutch ever goes (which I doubt) then I will put in a proper clutch.
Casey
Casey
[quote author=Casey Balvert link=board=20;threadid=23633;start=0#msg223069 date=1071342652]
Casey
[/quote]
Ditto to what Casey says. I don't think the benefit out weighs the risks. I have seen a lot of posts stating it was just as bad or worse after having the disc replaced.
Casey
[/quote]
[quote author=Sierra Phil link=board=20;threadid=23633;start=0#msg223225 date=1071371980]
"If it ain't broke, don't fix it." 8)
[/quote]
Amen to that ;D-Steve
[/quote]
UNDER-PRESSURE
15
01-27-2011 09:10 PM
Swamp_Donkey
07-09-2007 11:20 PM
