Tranny Problems
Old May 14, 2009 | 10:19 AM
JR GOUGH's Avatar
Tranny Problems
I've noticed on 2 different occassions that when my truck had not been driven for two days the tranny seems sluggish from the start. When I did get in and start to leave when i put it in drive it moved very slow and gradually got better. I think the torque convertor is draining out of fluid, is this a big concern I only have 37500 miles on my truck course you know these things are going to happen now that the warrenty is up
Old May 14, 2009 | 10:35 AM
GreyTD's Avatar
From what I have read and heard No it is not a concern, annoying yes. Put in N for 1/2 min, TQ will refill. Then away you go.
Old May 14, 2009 | 03:40 PM
no_6_oh_no's Avatar
Anti-drain back valve is sticking. Most of us update the VB to circulate in park then remove the valve for better flow thru the cooler.
Just train yourself to go into park for a minute or so before takig off and it should be good.
Old May 14, 2009 | 04:11 PM
JR GOUGH's Avatar
The only way to do the update (valve delete) is with aftermarket valvebody? Monday i'm scheduled to take it to the dealership should i upgrade now (VB, torque convertor, trans-go shift kit)????
Old May 14, 2009 | 06:29 PM
no_6_oh_no's Avatar
No, the Transgo kit will fix the circulate in park and boost your line pressures for longer trans life. Then you can remove the drain bacl valve for better flow.
Old May 15, 2009 | 03:53 AM
Dodgezilla's Avatar
My truck does the same thing. I start it up and put it in neutral for a minute or two. It's OK after that.....
DJ Turbo.
Oct 13, 2011 09:11 PM
Black Dog
Dec 3, 2009 08:18 PM
staken
Mar 5, 2008 07:41 PM
95 Dodge
Jul 2, 2006 03:28 PM
SmokinShaker
23
Nov 18, 2002 09:49 AM
