Which tranny do I have?
Old Aug 14, 2008 | 05:25 PM
dlkk's Avatar
I've got an 04 dtc with a 4 speed auto and i need to know how many quarts of atf to get. Thanks
Old Aug 14, 2008 | 05:41 PM
donhov's Avatar
Is yours an 04 or 04.5? Whatever it Probably has the 48RE tranny. I cant tell you haw many quats it takes though so hopefully someone else can answer fo you.
It helps to fill out your signature line so others can see what you have to be able to give you good related answers. Look on the side of the valve cover at the white tag and see what it says, 555/305 or 600/325. If the later you have the 04.5. It will also have a catalyic converter on it if an 04.5 as opposed to none on the 04. There are other differences but the above are the basic ones.
Old Aug 14, 2008 | 08:38 PM
ib516's Avatar
Make sure you use ATF+4.
TSB Link
Bradleysram
19
May 12, 2009 08:36 AM
Trooperthorn
Jul 25, 2008 10:39 AM
Strjock81
Jan 9, 2005 08:31 AM
betsycam
Sep 9, 2004 02:59 PM
w4xtc
May 14, 2003 02:49 PM
