Towing w/stock clutch and Smarty?
Old May 20, 2008 | 08:56 PM
TaylorP's Avatar
I am planning on buying a good clutch some time soon, but it is really not in the budget right now. So in the meantime, I tow around 7000-8000lbs, what setting do you guys run to keep your stock clutch happy?
Old May 20, 2008 | 09:17 PM
snoyes's Avatar
I'd probably keep it on Level 3 if you are going to pull consistently with the Smarty. Don't slip the clutch and you should be fine.
Old May 20, 2008 | 09:59 PM
TweetyBird's Avatar
I pull 15K on settings 1 and 2 with no problems......
Old May 21, 2008 | 06:59 AM
MikeyB's Avatar
I keep mine on level 5 but seeing your truck having 3.73's and 315 tires I would keep it at level 3.
MikeyB
Old May 21, 2008 | 04:36 PM
TaylorP's Avatar
thanks guys I think i will set it to level 3. I will try it out this weekend to see how it does over the hills.
bigdaddy51200
43
Nov 18, 2011 06:23 PM
zylberberg
Jun 17, 2008 01:44 PM
mxdsl183
May 25, 2008 10:01 AM
D.Wiggs
31
Aug 30, 2007 02:48 PM
qwest
Dec 3, 2006 01:11 AM
