Too much trans fliud
Old Nov 12, 2008 | 10:35 PM
retiredchuck's Avatar
Need help,Is there a way to remove some trasmission fliud without removing the pan.The dip stick shows the fliud level pass the word MAX on the stick.I need to bring it down.Thanks in advance for any sugestions.
Old Nov 12, 2008 | 10:48 PM
04DEEZELRAM's Avatar
when i put my trans in i but to much fluid in, so i took one of the cooler line loose and had a buddy crank the truck and i held a bucket and caught the fluid only way i could think of
Old Nov 12, 2008 | 10:49 PM
worldindustries's Avatar
I thought there was a drain plug, but I can't remember now
Old Nov 12, 2008 | 11:48 PM
annabelle's Avatar
No drain plug. How far past max does it read?
Old Nov 13, 2008 | 12:59 AM
itr.#1446's Avatar
that is prob the best way to do it
Old Nov 13, 2008 | 01:58 AM
67HotRod's Avatar
If its just a little past MAX its not going to hurt it.
Old Nov 13, 2008 | 06:52 AM
04ctd's Avatar
no, it is not.
go to northern tool, they have a MityVac Siphon for $15.
i would recommend getting it out ASAP.
I overfilled mine, and it started doing the stuttuttuuuttuuuuttterrreer shift,
and i pulled some out, but it still stuutututers.
Old Nov 13, 2008 | 07:00 AM
04ctd's Avatar
http://www.northerntool.com/webapp/w...8074_200008074
Item# 3316152
Only $24.99
Old Nov 13, 2008 | 08:47 AM
no_6_oh_no's Avatar
Its fine, don't worry unless your seeing fluid coming out the breather and onto the ground under the truck. You can run the trans 1-2 quarts over full depending on how the stick is marked and its a good thing. Extra fluid is always a plus.
Old Nov 13, 2008 | 10:13 AM
The fliud level goes past the word MAX up to the loop bend on the dip stick.The manual states not to overfill the trans because it will shorten its lifespan.I dont want to bring it back to the dodge dealer because they are the ones who overfill it.I will never go there again.If I can do it myself,thats what I will do.Its a shame that you can not trust the Dodge dealers,I have had too many bad experiances with them.But I will be force to use them on warranty work only.
Old Nov 13, 2008 | 10:44 AM
annabelle's Avatar
Probably not a problem, but siphon it out if it make you feel more comfortable.
Old Nov 13, 2008 | 01:13 PM
SOhappy's Avatar
Been there, done that, have the t-shirt
A big syringe (Auto parts/motorsports stores have them for mixing 2-stroke oil) and some clear plastic tubing (available at a hardware store) is the cheapest and easiest solution I found. Just suck it out the dipstick tube.
dieselJon
Jan 3, 2011 08:18 PM
jjrightmire1973
Nov 20, 2008 08:20 AM
ptm600
Jan 31, 2006 07:43 PM
doubledodge2003
Feb 20, 2005 01:48 PM
csaverline
Dec 8, 2002 07:18 PM
