fliud capacities?
Old Feb 19, 2005 | 05:10 PM
doubledodge2003's Avatar
fliud capacities?
could someone give me the fluid capacities on the 2003 dodge ram with cummins for the 6 speed manual tranny, the front and rear differental, and the transfer case??
Old Feb 19, 2005 | 06:12 PM
jlbrown's Avatar
Don't know which one you have. Hopefully this covers yours If not let me know.
Transmission
NV5600-4.9L(9.5pts)
NV4500-3.8L(8.0pts)
Transfer Case
NV273 or NV271-1.89L(4.0pts)
Front Axle
9 1/4 AA- 2.25L(4.75pts)
Rear Axle
11 1/2 AA - 3.62L(7.65pts)
Old Feb 19, 2005 | 09:06 PM
Equalizer 2's Avatar
I haven't done the differentials or transfer yet but just did my NV5600 on Thursday and all I could get in it was 4 quarts. I drove it about 100 miles yesterday so now I will crawl under and check the level this weekend.
When I put the 4th quart in it started running out the fill hole as I was hitting the bottom of the bottle.
Old Feb 20, 2005 | 09:02 AM
jlbrown's Avatar
Don't know about the 2004.5 but the information came out of Dodge's DR 2003 Maintenance manual.
Old Feb 20, 2005 | 09:31 AM
Jerry R's Avatar
When changing the fluid in the NV5600 you have to park it nose down or jack up the rear.
Old Feb 20, 2005 | 10:21 AM
rossn2's Avatar
Spreadsheet info I've kept on my 04 2500 with 6spsd, 3.73 rear 4x4 since Jan 2004.
Engine Oil (11 Qts/ 12 w/filter)
Man. Trans. NV 5600 ( 6 Spd 9.5 pts/4 qts)
Frt & Rear Axle (3.73) (up to 5 pts frt & 8pts rear/8 qts)
Transfer Case (up to 5pts/3qts)
Just did the rear end and transmission last Friday evening and it was 4 quarts in each with oil just dripping out of trans and about 1/4 inch below rear fill line.
Old Feb 20, 2005 | 11:48 AM
thanks fo rthe reply guys, just need to know how much of what fluids i need to order, since i dont drive but about 5,500 miles a year and dont tow anything i figure better to pay more and get the good stuff for the drivetrain, so whats better REDLINE OR AMSOIL?
Old Feb 20, 2005 | 12:25 PM
I used Royal Purple Synchromax as it was listed as fitting the part number and the MS #. Redline had MTL listed but I have read where people have not received a satisfactory answer on using AMSOIL.
I emailed Royal Purple and asked how I would be able to show that they met the OEM requirement and they replied that if DC was a problem then they would stand up for their oil as long as it wasn't contaminated or low when the failure occured.
When I changed out the tranny I jacked up the rear end so the truck was a little nose down and let it drain for about 2 hours. Then I filled it up while it was in the same position. Drained the oil into a 5 quart jug and it only came up to about the 4 quart level.
Old Feb 20, 2005 | 01:48 PM
rossn2's Avatar
Amsoil does not make a Tranny fluid for the 6spd. The tech line recommends motor oil? That's why I run the Redline MTL.
I don't jack up the vehicle, just roll around underneath. The PTO bolt is already at the lowest point of the transmission.
13
Feb 16, 2012 09:48 PM
retiredchuck
Nov 13, 2008 01:13 PM
ptm600
Jan 31, 2006 07:43 PM
tarpilot
Sep 27, 2003 04:46 PM
bdog
Dec 18, 2002 05:55 PM
