Tire speed =RPMs
Old Nov 22, 2006 | 06:10 AM
MOJO1's Avatar
Question Tire speed =RPMs
Got a question my 6sd runs 2k at 65 mph 2.3k at 70 mph.Dose that sound about right? Seems to be high to me. My auto has 410s & 315 tachs lower.(Help me understand this) Thanks
Old Nov 22, 2006 | 06:50 AM
ptm600's Avatar
That sounds about right to me yours should be a little higher rpm than mine being you have the g56 6 speed. Mine is at 2k at 68 mph. The auto tranny has a lower ratio producing lower rpm. Your 315 tires are really what get the r's down on the auto though.
Old Nov 22, 2006 | 08:44 AM
MOJO1's Avatar
So the only way to get the rpms down is to do a gear swap or bigger tires?
I realy dont want to do a gear swap but dont wnt to lift the truck eather. I guess im doing one or the other. Trying for better fuel milge.
Old Nov 22, 2006 | 09:15 AM
nitis's Avatar
have you calculated that you are about 10% off on your speed so your speedo reads 65 but you are really doing 71 I have 315 70 17 so yours are slightly taller than mine and I figured this out going accross idaho I knew I was off but that made me feel better.
Old Nov 22, 2006 | 10:50 AM
MOJO1's Avatar
I took mine to the dealer he programed it as close as possible im about 2 over.
Old Nov 22, 2006 | 11:01 AM
dodgezilla04's Avatar
you could put a gear vendors overdrive on it. kinda like an aux. trans. $spendy though$
Harbaw
Mar 27, 2008 12:42 PM
ARAcummins
Jul 5, 2003 09:47 PM
RLS
Jan 28, 2003 10:56 AM
iwannaram
24
Dec 20, 2002 11:56 PM
