Chugging at 1500 to 2000 RPMs pulling a load but pulls fine over or under these RPMs
Old Dec 26, 2009 | 10:07 AM
jschintgen's Avatar
I may need some pro help here. I have an 02, 3500, 6 speed, 5.9, stage 3 injectors, EZ edge box, 6" exhaust. When pulling, steady pace or climbing from 1500 to 2000 Rpms it will jerk / hammer / chug like it's missing and you can feel it hard in the driver seat but if I give her to over the 2000 RPMs (over 70 MPH in 6 grear) or keep it under 1500 RPMs (under 50 mph in 6th gear) she will be fine and runs fine so I don't think it is a fuel problem since there is plenty of power and pickup after 2,000 arps but not sure what it could be.. not sure. Any help would be a lot! It does the same thing with or without the EZ edge box plugged in. Thanks.
Last edited by jschintgen; Dec 26, 2009 at 01:21 PM. Reason: update with EZ box unplugged
Old Dec 26, 2009 | 10:39 AM
Copenhagenjunkie's Avatar
Remove ez and test drive. Check codes with key cycle- on-off-on-off-on, do not start. Look at odometer screen for codes.
Old Dec 26, 2009 | 10:53 AM
johnh's Avatar
Originally Posted by jschintgen
I need some pro help here. I have an 02, 3500, 6 speed, 5.9, stage 3 injectors, EZ edge box, 6" exhaust. When pulling or climbing at 1500-2000 Rpms it will jerk / hammer / chug like missing and you can feel it hard in the driver seat but if I give her to over the 2000 RPMs (over 70 MPH in 6 grear) or keep it under 1500 RPMs (under 50 mph in 6th gear) she will be fine and runs fine so I don't think it is a fuel problem but not sure what it could be.. not sure. Any help would be a lot! Thanks.
pulling a load at 1500 rpm is lugging the engine... shift down or don't give very much throttle and it shouldn't "chug"
Old Dec 31, 2009 | 06:01 PM
jschintgen's Avatar
Edge unhooked, No codes. Truck is jerking like crazy under load - don't think it is a fueling issue. What electrical problems would cause this?
Old Dec 31, 2009 | 11:17 PM
johnh's Avatar
possible bad injector, have them pop tested......
13ALPHA
24
May 4, 2012 01:15 PM
jdddually
Jun 16, 2011 09:18 PM
gncc 621
Feb 9, 2009 09:48 AM
deanoz13
Jan 21, 2005 06:46 AM
