Is there a drain plug in the torque converter.
Old Jan 12, 2006 | 10:53 PM
Prodart440's Avatar
If you are going to drill a hole DO NOT do it on the engine side of the converter. The lock up clutch is located there and you will ruin the surface that it rides on. That is the reason they no longer come with drain plugs. You could drill one on the side, and hope you don't hit anything, and hope it doesn't leak. But I wouldn't try it.
Old Jan 13, 2006 | 12:00 AM
BigBlue's Avatar
When I did mine I just loosened the bolts on the valve body a few turns and let it drain for about an hour. Went through and tightened everything back up and ended up having to put 11 quarts in a tranny that only holds 12 (before the double deep pan). Worked great for me.
Old Jan 13, 2006 | 12:38 AM
Bad Ramer Jamer's Avatar
Originally Posted by underwoodtransp
I think that will go over like a fart in church.. Thats why I started my own business to hide the mods under "business expense" it is called "automobile maintence". She doesn't know half the stuff I buy anymore.
I think that little secret is worth some hush money. And don't bother deleting it, cause I printed it out. I'll settle for a case of ATF+4
Old Jan 13, 2006 | 12:40 AM
I think the biggest problem with drilling a hole in the converter is it would make it out of balance. But that's just a theory though. I bet they balance the aftermarket convertor's.
Old Jan 13, 2006 | 01:04 PM
eastmentCTD600's Avatar
Forgive me for my ignorance, but don't you need some kind of boss to tap into for the threads of the plug you want to install, the converter housing is probably far too thin to tap sucessfully.
Furthermore, as stated earlier, its a crap shoot as far as hitting a blade/fin, and what about the metal chips you'd produce while driling and tapping?
Doesn't seem practical. Can anyone speak to the converter housing thickness?
Old Jan 14, 2006 | 12:10 PM
underwoodtransp's Avatar
hows about some amsoil... I don't use anything other than the air filter that says mopar on it. Everything in my truck for fluids are amsoil.
All in all she does know "some" of the things that the "company needs" but for the most part she is too ignorant to see them. I will admit that the company owns a few pretty nice things that are used more for personal than company purposes. Examples: pressure washer, welder, air compressor. But I do have to say "I" own the hand tools. There is nothing wrong with buying things under the business name to save for tax purposes since they are used to maintain the company's equipment.
y2kram
May 2, 2010 03:37 PM
hovisimo
Nov 30, 2007 10:17 AM
Pop
Jun 1, 2006 12:09 PM
johnpenxa
May 19, 2006 03:51 PM
TexasCTD
Apr 13, 2005 09:38 PM
