is ther a gov on my truck
I have an 04 1/2 ram 6 speed is the speed gov or a rpm gov on my truck from the factory due to haveing 4 10 gears are anything just tring to know if its my gearing that its not as fast as i thought or is there something limiting my truck and the edge computer
The Cummins has a high idle set-point in the ECM. Once you reach it, you're done. There may also be a speed limiter set-point to limit vehicle speed, not sure. If there isn't a vehicle speed limiter, whatever speed you make it to when the engine reaches high idle in top gear is all you can get. Only way around it is to alter the RPM limiter.
If you're just looking for accelleration, not top speed, its just a matter of adding fuel and increasing boost.
Taller tires or a gear swap can help lower the RPM and increase vehicle speed, but you will have to recalibrate the speedo for the different ratios..
mknittle
Mar 21, 2015 10:18 AM
fishin fever
Mar 13, 2006 06:46 PM
crossy
May 26, 2005 09:09 AM
