Is ther anywhere that has pictures of fuel plates
Old May 25, 2005 | 09:36 PM
crossy's Avatar
Just curious so maybe I can find one that doesn't hit so hard in just one spot like this #6 does. thanx , DAVE
Old May 25, 2005 | 09:47 PM
mr T's Avatar
#10 is smooth and gradual...# 100 is better ..its a #10 with no defuel at the top.....do a search on fuel plate pics and you'll find pages and pages
i assume u have gauges right?? since u already have a BD trans then u can run the #100 plate and enjoy...ur right foot controls everything with that one and slide it back and forth depending on ur liking and ur egts the #100 looks like a "J"
Old May 25, 2005 | 09:56 PM
crossy's Avatar
I tried the searches with exactly those words before I posted and I thought I would come up with lots of pics but I wasn't having any luck at all. My #6 is full front will moving it rearward soften it up any? or cut peak power only ? I also noticed the afc has slotted holes . what would that need adjustment for ? can you tell I'm new at this performance stuff :-) ,
BTW- Pyro , boost & tranny/oil temp gauges. DAVE
Old May 26, 2005 | 12:23 AM
mr T's Avatar
no problem buddy have u ever adjusted ur cam lever in ur pump? so that it hits ur plate properly?
http://www.piersdiesel.com/TechLeverAdj.htm
https://www.dieseltruckresource.com/...e&pagenumber=2
there's a pic of the #100 plate IMO the ultimate/best plate ...u will never need another one...a tranny like urs is definitely necessary to run this
Old May 26, 2005 | 08:56 AM
crossy's Avatar
yeah , I actually did that and have it just at the nose of the plate,but now I'm wondering if it wouldn't be best to have it 1/8" below the tip of the nose so it gets a little ramp up before the surge?. I assume that the big rush of power I get is when the lever falls down the straight top of that nose(moving upward from bottom)? am i right?. another issue I'm going to post about is the tranny still shifts at OLD RPM setting and does not take full use of the extra 300RPM I gained with the 3K GSK before shifting and seems to shifter even sooner and softer at 'normal' driving. thanx , DAVE
Old May 26, 2005 | 09:09 AM
HOHN's Avatar
Check out Forrest Nearing's member's gallery....
jlh
mknittle
Mar 21, 2015 10:18 AM
stroker400
Sep 21, 2007 12:59 PM
Bean
Sep 10, 2007 09:33 PM
Mcmopar
Jan 20, 2005 06:33 PM
