T-Case problems
Old Apr 13, 2007 | 11:38 PM
Boz007's Avatar
T-Case problems
What would cause my transfer case to not shift into 4wd (electronic shift)? I was backing up a trailer this evening in some slick stuff and went to put it into 4wd and all i got was the light blinking forever. I turned the truck on and off a few times and it finally shifted. Same thing with getting it out of 4wd.
Old Apr 14, 2007 | 12:13 AM
pooperscooper's Avatar
Were you moving? Unless you were trying to put it in low range, they like to be moving to lock into 4high.
Old Apr 14, 2007 | 07:15 AM
Boz007's Avatar
I tried moving (i couldnt move very far cause id just start spinning), i tried putting it in 4lo. When i finally got out of the situation it was just as much a pain to get out of 4wd as it was to get in. When i got home though (actually after i started this thread and was leaving the house again), i tried it again and it popped right into 4wd so i dont know.
Old Apr 14, 2007 | 08:23 AM
Heater's Avatar
My experience with electronic shift was moving was very important. For 4 low coast at less than 5 mph while neutral and it will shift right in and out
Old Apr 14, 2007 | 09:10 AM
06trx's Avatar
I work at NPG , and what I have seen is that the shift motor sucks!! They throw out about 20% of the motors because they don't work right. That is why I got the lever on the floor. The problem isn't gust Dodges it all the cases we make. I think it's just another case of the lowest bidder wins. Jeff
Old Apr 14, 2007 | 12:10 PM
1sttruck's Avatar
I have a manual transfer case, and find that it works fine. Having worked in manufacturing it's obvious what they'll do for raising prices and cutting costs, which is adding more cheap, failure prone electronics.
Old Apr 14, 2007 | 01:07 PM
Boz007's Avatar
I really wish i had the manual lever but the dealership was lacking in that department. Hmmm, i wonder how hard it would be to swap. I have no problem cutting a hole in the floor to fit the lever.
Old Jun 12, 2007 | 05:18 PM
Thundercloud's Avatar
Is it possible to switch to a manual lever?
I am reopening this thread in hopes of finding out what it would take to convert the electrionic shift transfer case to a manual lever one. I had trouble last weekend shifting into low range, whether stoppped or rolling 5 mph in neutral. Does anyone know if this could be done?
Old Jun 12, 2007 | 05:34 PM
matt ellerbee's Avatar
Iwas thinking about this as well, i have removed the litte tray where the shifter would be on mine acouple of weeks ago and there some bolts that look like they hold down a plastic or metal cover. my guess is all you would need would be the linkage and lever assembly, but i am not sure about this, thats just what it looks like.
Someone give us electronic shifter guys some help!!!
Old Jun 12, 2007 | 10:14 PM
06trx's Avatar
I'll check this out. I know that when we make them , thay have a differant case half for each. Jeff
Old Jun 13, 2007 | 12:10 AM
Thanks Jeff for looking into this, I'm sure us electronic guys will be very interested in hearing what you find. I wonder if a mechanic at the dealership would know?
Old Jun 13, 2007 | 03:55 AM
06trx's Avatar
Well I went to the assm. line and talked to some of the guys there. It they said you would be better off getting a man. shift case. The big problem is that you would have to change the shift posioner , because the shafts are different, as well as how the shaft is sealed is different. I also talked to a guy in the test garage, he said you need to be stopped and in nutral to put it in 4 lo. other than that you should be able to shift in 4h at any speed(he thinks its below70 or 80) I hope this sheads some light on what you are looking for. Jeff
Old Jun 13, 2007 | 11:00 AM
So what you are saying Jeff is that I would need to replace the entire transfer case with a manual shift one in order to make it work?
Old Jun 13, 2007 | 05:36 PM
06trx's Avatar
Plus you would need to rig up the shifter.
DJ Turbo.
Oct 13, 2011 09:11 PM
wyododge
Aug 18, 2011 07:48 AM
dieselman24
Jan 27, 2004 06:02 AM
hw101
Mar 16, 2003 12:07 PM
