Surging at highway speeds
Old Dec 9, 2003 | 11:49 AM
trailblazenyj's Avatar
Ok, this started about 3 or 4 weeks ago. After about 30 minutes on the road and at steady speeds (around) 65 - 70 I start getting random engine surges. Can't see any fluctuation in the tach but I am getting 4 - 5 pound swings on boost. Feels like I am losing fuel. Thought at first it was bad fuel. Changed the filter and have been through at least 5 tanks since it started. No difference. Next thought was fuel pump starting to fail. Don't have FP gauges (yet) so I don't have any proof but if I drop a gear and hammer it I don't have the problem. So, I don't think I am starving for fuel. So now I am thinking wastegate fluctuation? Don't have any good ideas on how to verify this.
Anyone have any suggestions? Besides the fact that it is annoying I just hate it when things don't run right.
Other things:
1) Used fuel from several different high volume locations and have filled the Ford there at the same time with no ill effects
2) When I changed the filter the old one had about 12k on it and didn't look bad at all. No gunk.
3) Have not had any water in fuel indications and drain down regularly.
Thanks, Mark
Old Dec 9, 2003 | 09:14 PM
CTDinMT's Avatar
Re:Surging at highway speeds
I think Dodge has a computer fix for that, seems like I've heard of it here before. I think the dealer just flashes your computer to fix it. Call your dealer and have them take care of it.-Steve
PS- Were you running cruise control, cause now that I think of it, I think the surging prob was while using cruise...
Old Dec 10, 2003 | 10:24 AM
Happened with and without cruise on. Remembered the cruise control thing. Was waiting to see if anyone had other ideas before getting a re-flash done. Truck has been perfect up to know and didn't want to mess with the computer if I didn't have to. Thanks.
Old Dec 10, 2003 | 09:40 PM
Zeedaddy's Avatar
Mine does that when my 48RE shifts into OD...it feels like its kicking you back in the seat....Not sure if thats a good thing or not ???
Old Dec 20, 2003 | 10:42 AM
Well it started surging so bad yesterday I thought it was going to finally die. Went by a small town dealership to see if they could check it out. Went through the book and checked for loose hoses etc. They admitted they didn't work a lot on diesels. They didn't find anything but re-flashed the computer just in case. Surge is still there. Guess I am going to have to resign myself to leaving it at a local dealer for several days.
Thinking seriously about investing in some software for the laptop too see if I can capture the data when it starts happening. Maybe then somebody could diagnose it.
Sigh...
Old Dec 20, 2003 | 12:50 PM
GoHiSK1's Avatar
My 03 surges a bit with the cruise on and I also see a 3 to 5lbs. of boost swing with no RPM increase or decrease but I can can feel it in the seat of the pants.
It has been doing this since new and I took it back to my dealer for this problem and they installed a new cruise actuator? Still have the same problem. Have not been back to garage yet to tell them problem still happening.
Old Dec 21, 2003 | 09:26 AM
spots's Avatar
Mine has also done this since new. Only with the cruise on. 28k now.
Old Dec 21, 2003 | 07:16 PM
GotCummins?'s Avatar
My 03 does this in cruise AND will contunue to do so for about 30-40 miles when cruise is turned off. I have tried this many times and it holds true. About 40 miles after cruise is turned off it goes away. Stop using cruise control (if you do) and drive at least 40 miles without using cruise at any time and see what happens. Please let us know.
Hope this helps.
Chris
03 2500 HO, 6speed
Old Dec 26, 2003 | 06:58 PM
cma1day's Avatar
mine does it with or without cruse.....does the reflash solve the problem??
Old Mar 3, 2005 | 11:48 AM
HOUTEX's Avatar
Mine Dosn't Seem To Have This Problem..
Spitse
Jan 21, 2006 06:36 PM
crobtex
19
Dec 19, 2004 08:08 PM
jnaker
36
Dec 10, 2003 06:02 PM
Zeedaddy
96
Aug 25, 2003 08:00 PM
RLS
24
Jan 9, 2003 12:23 PM
