Stupid seatbelt annoyer
Old Dec 11, 2008 | 06:43 PM
Fisherguy's Avatar
What's the joystick for?
Old Dec 11, 2008 | 07:27 PM
megacabdad's Avatar
Factory option...Atari.
J/K, it's for the snowplow...
Old Dec 12, 2008 | 11:33 AM
davidj54's Avatar
Here's how I did it.
NOTE: The following steps must occur within the first
60 seconds of the ignition switch being turned to the ON
or START position. DaimlerChrysler does not recommend
deactivating the Enhanced Warning System
(BeltAlert).
1. Turn the ignition switch to the OFF position and
buckle the driver's seat belt.
2. Start the engine and wait for the Seat Belt Warning
Light to turn off.
3. Within 60 seconds of starting the vehicle, unbuckle
and then re-buckle the driver's seat belt at least three
times within 10 seconds, ending with the seat belt
buckled.
NOTE: Watch for the Seat BeltWarning Light to turn on
while unbuckling and off while re-buckling the seat belt.
It may be necessary to retract the seat belt.
Old Dec 12, 2008 | 11:12 PM
nodakbassmaster's Avatar
I had the dealer shut the alarm off...
Old Dec 12, 2008 | 11:29 PM
Cummins610's Avatar
Here your go, no splicing nothing:
Verbatim from the Manual:
1. With all doors closed and the ignition switch in any postion except On or Start, buckle the driver's seat belt.
2. Start the engine and wait for the Seat Belt Warning Light to turn off.
3. Within 60 seconds of starting the vehicle, unbuckle and then re-buckle the driver's seat belt at least three times within 10 seconds (I did it exactly three), ending with the seat belt buckled.
4. Turn off the engine. A single chime will sound to signify that you have successfully completed the programming.
The Enhanced Warning System (BeltAlert) can be reactivated by repeating this procedure.
NOTE: Although the Enhanced Warning System (BeltAlert) has been deactivated, the Seat Belt Warning Light will continue to illuminate while the driver's seat belt remains locked unbuckled.
Old Dec 13, 2008 | 01:08 AM
CrashCade's Avatar
Originally Posted by jivemother
i was hoping it stop when the door was open also ... so it still honks horn if door is open and u move ?
No, if you jump the wires, the horn will not sounds. The truck thinks the seat belt is plugged in.
Jim Lane
Mar 23, 2013 09:31 PM
bigredbrick
Jul 13, 2008 04:12 PM
usmc2311
Nov 17, 2007 09:27 PM
Hoss
May 19, 2005 02:28 PM
JKM
Mar 22, 2005 06:29 AM
