Strange Noise
Old Mar 5, 2007 | 04:31 PM
Stealth06Ram's Avatar
Strange Noise
Oh, the hard to diagnosis Noise.
Actually, I have this "Clunk" comming from the rear under the following condition's;
Movingin slowly, on and off the gas, the clunk occurs when the driveline is unloaded.
Upshifting, Auto, 1st - 2nd clunk, drive line loaded.
Coasting, Clunk, Driveline Loaded, Unloaded.
Now I think that it a loose u-joint, but I have not checked, (Manualy tried to twist the drive shaft in park to check for Play.
Truck has 1800 Miles, has done Light Towing (1200 Pounds Max). But I heard the Noise before the Towing.
It's not getting worse. But it is noticable.
So,
When I check the Drive Shaft to see if it twists, should it move at all? If so, how Much?
How can I check the rear diff?
Any Ideas? Or is it just Normal?
3.73, Auto, Limited Slip.
Stealth.
Old Mar 5, 2007 | 04:37 PM
Road Traveler's Avatar
Check your carrier bearing! When mine went out it was a pretty hard one to find!! As far as your u-joints go you shouldnt have play at all! Sometimes they are hard to find by hand but what you can do is drive it 4 a while and work the driveline pretty ruff such as a bunch of stop and go where you are upshifting and down shifting and feel all the U joints most of the time the one that is bad will be a lot hotter than the others!
Hope this helps!
Old Mar 5, 2007 | 04:42 PM
Uhh,
What and Where is that?
Stealth
Old Mar 5, 2007 | 04:44 PM
Carrier bearing or center bearing!
It is halfway down the drive line mounted to the truck with 2 bolts and the driveshaft goes through it. Almost in the middle between the tranny tailshaft and the front of the pinion!
Old Mar 5, 2007 | 04:54 PM
Thanks,
Stealth
Old Mar 5, 2007 | 04:59 PM
No problem at all! Hope you figure out what it is!
torq
19
Dec 30, 2005 05:59 PM
heavyg
Jun 24, 2003 07:43 AM
DarrellB
Mar 3, 2003 06:26 PM
Gregor
Dec 3, 2002 12:18 AM
heavyg
Oct 25, 2002 05:06 AM
