straight to high idle?
Old Feb 16, 2006 | 10:43 AM
mule3010's Avatar
I have noticed that if I start my truck, not plugged in while in the single digits it goes straight to high idle(1000 rpm) without the normal delay. Do others trucks do this as well?
2004.5 QC 4x4 48re
Old Feb 16, 2006 | 11:07 AM
ptm600's Avatar
I've had mine do it 2 or 3 times on cold days when leaving work. I believe it's normal.
Old Feb 16, 2006 | 11:40 AM
Nate-03 D's Avatar
How cold does it have to be before the high idle feature kicks in?
Old Feb 16, 2006 | 12:41 PM
Jeff in TD's Avatar
Mine does it with a delay in the upper or mid 20's. Colder and not plugged in and it will do it as soon as started.
Turning on the jake while high idle is on really helps heat things up...
Old Feb 16, 2006 | 02:22 PM
Hounddog's Avatar
All 03s up do this.
Old Feb 16, 2006 | 04:13 PM
Dorkweed's Avatar
Muted User
From: "The Peoples Republic of Illinois".....behind enemy lines
If I don't plug my truck in, sometimes it goes right into the high idle and other times it has to run a couple minutes before it will. I can't really find a pattern to it.
Old Feb 16, 2006 | 07:23 PM
BlueDually's Avatar
I think they all do this, it takes 2 minutes before the 1000 rpm idle if the coolant is less then X degres and not touching the brake or fuel
same with the instant start up 1000rpm, I hold on the brake til it slows down, the espar eliminates any cold start up problems
kicker210
Dec 2, 2009 08:23 AM
cwrhnr
May 19, 2009 05:18 PM
jmccart
Jun 12, 2007 02:12 PM
natlchamp2k4
Dec 6, 2005 09:38 PM
yarddog
Aug 30, 2005 09:01 PM
