Stinky Exhaust
Old Dec 31, 2009 | 09:00 AM
Huntsville 3500's Avatar
Stinky Exhaust
Hope everyone here had a great Christmas...
My 03 3500 TCD has been having an unburnt diesel smell on shut down. 124K, All stock parts.
Any ideas as to what to check first??
You all have a safe new years!!!!
Thanks
Vic
Old Dec 31, 2009 | 09:04 AM
Lost Lake's Avatar
I have no idea, but I can guess!
Diesels are compression engines and as such need to shut off fuel to stop. I would guess either the fuel shut off is leaking a bit, (do the injectors just remain closed? Then an injector would be leaking) or you have a fuel leak somewhere and you are just smelling it after the truck has run and been pumping fuel.
How does your oil analysis look? That would quickly show you fuel in your oil.
Old Dec 31, 2009 | 02:51 PM
1985cucv's Avatar
answer these questions
is your oil level high?
do you have white smoke on start up?
does it take long to crank over and start up?
do you run rotella oil?
Old Dec 31, 2009 | 04:06 PM
is your oil level high? : no
do you have white smoke on start up? No
does it take long to crank over and start up? No
do you run rotella oil?Not sure. I got the truck in June, The dealer had just changed the oil, I'm due to change the oil now.
Thanks
Old Dec 31, 2009 | 08:28 PM
Spooler's Avatar
You probably have a fuel leak somewhere. Do you notice any wet specs on your tailgate?
Old Jan 1, 2010 | 06:00 PM
1985cucv's Avatar
rotella made my truck smell like diesel for a long time for some reason. changed to delvac now its fine. i would check for fuel leaks as well maybe the vent on your gascap is causing the smell?
FunFinder5
Oct 31, 2009 01:48 AM
DeanM
Mar 12, 2007 06:58 PM
mhuppertz
Oct 30, 2006 04:32 PM
betsycam
27
Jul 23, 2004 09:12 PM
gofastman
Apr 8, 2003 08:38 PM
