Stalling and lack of power issues???
Old Jun 16, 2011 | 01:26 AM
Mykdiver's Avatar
Question Stalling and lack of power issues???
Ok, so sometimes I as I am pulling up to a light the truck dies, then according to my Quadzilla gauge the fuel rail pressures are between 3K and 4K no matter how hard I floor the accelerator, and the truck really lacks power. This is an intremitent problem as it does not happen all the time.
Does anyone have any ideas??
So far I have drained the fuel water separator and just found a couple little bubbles of water, nothing much, I also replaced the fuel filter.
Old Jun 16, 2011 | 08:59 AM
Adaminak's Avatar
I'd say the first spot to check is your lift pump. If it's dead, you won't get a reliable supply to the CP3, which can affect your rail pressure.
Old Jun 16, 2011 | 01:56 PM
2hipsi's Avatar
As said, check lift pump pressure and it could be a faulty FCA valve. Have you tried checking for codes with a scanner?
Also, is the quad gauge one of the original rail pressure gauges?? From when they first came out?
Old Jun 16, 2011 | 09:01 PM
Mykdiver's Avatar
No I just got it a couple of weeks ago.
archer39
Jun 16, 2012 03:16 PM
archer39
Mar 26, 2011 08:55 PM
90dodge
Jun 12, 2008 03:08 PM
mooktank
Dec 6, 2006 11:11 PM
Holsteinman
Mar 16, 2004 11:39 PM
