Engine loping and lack of power
Old Mar 24, 2011 | 07:23 PM
archer39's Avatar
Lately I have been noticing a lack of power while at WOT. When i come to a stop after going WOT the truck begins loping really bad and runs rough. My fuel pressure is staying right around 12psi and is not fluctuating. I have a new fuel filter (~1000 miles on it) installed. It only does it now and then and only does it after going WOT. Otherwise the truck runs smooth and has full power.
any ideas?
Old Mar 25, 2011 | 12:27 PM
dstad's Avatar
Injection pump could have internal probs, like an out of place oring or something. Almost sounds like its slightly sucking air. Just my 00.02, idk alot about the ve internals
Old Mar 26, 2011 | 06:28 AM
archer39's Avatar
my first thought was something was wrong with the VE. I had issues with it sucking air before and i would notice a fluctuation in fuel pressure and that is not the case now.
Old Mar 26, 2011 | 12:10 PM
cougar's Avatar
After WOT?
Is your fuel pressure lower than before at WOT?
Lift pump, fuel filter, dirty injectors?
Old Mar 26, 2011 | 05:51 PM
archer39's Avatar
Originally Posted by cougar
After WOT?
no about the same. At WOT it has always dropped down to around 9psi and that is what it is still doing.
Old Mar 26, 2011 | 06:26 PM
Trebor's Avatar
Take about a 4 ounce fuel sample from the fuel filter and let it set for a while in a clear glass container. Check it for water. Water can get into a fuel filter and cause a partial blockage by displacing some of the fuel.
Old Mar 26, 2011 | 08:55 PM
archer39's Avatar
ok, i will do that. It has been occurred with every fill up but i only get fuel from one place. maybe they have bad fuel.
rage_blue
13
Apr 5, 2009 11:47 PM
smkn97s
Jan 25, 2007 09:10 PM
01smokin
Jan 13, 2007 02:27 PM
BigBlue
Nov 20, 2002 05:22 PM
