sounds like turbo bad not sure....
Old Oct 10, 2011 | 09:05 PM
1buck4me's Avatar
It all started when i would not get very good boost. I pulled the hose to my wastegate becouse the command valve was premuturly leaking and opening the waste gate. So i pluged the hose. and was able to get great boost.But now under a load I get this strange noise like my truck burps most boost. egt's stay down and boost drops about 10psi.I think i'm going to order a new command valve and reconnect the wastgate. What do you think it is, could it be fuel shutting down and doing this or is the turbo bad. no engine codes, i'm not sure what to do...
Old Oct 10, 2011 | 10:47 PM
1buck4me's Avatar
can some one help? do i need a new turbo? I only have 91,000 miles on my truck
Old Oct 10, 2011 | 10:49 PM
1buck4me's Avatar
I also have the edge juice and cfm intake
Old Oct 11, 2011 | 04:53 PM
dfl5150's Avatar
Try disconnecting the juice
Old Oct 11, 2011 | 08:09 PM
AH64ID's Avatar
You could be blowing the wastegate open with drive pressure. I would do it at about 55 psi of drive pressure, which was 35ish psi of boost.
Old Oct 11, 2011 | 11:00 PM
1buck4me's Avatar
what is drive psi. I asked a turbo guy that and he said it was not possable. Not sure how the wastegate is designed?
Old Oct 12, 2011 | 05:33 AM
AH64ID's Avatar
Drive pressure is the pressure in the exhaust manifold, runs about 2:1 on a stock turbo under WOT.
It's possible.
Old Oct 12, 2011 | 08:38 AM
prlsnpsdodge's Avatar
Is there a way to tell if the wastegate is working properly without having a boost guage? I ask because I dont usually feel the truck take off until myr rpm's are close to 1800-2000...
Old Oct 12, 2011 | 09:43 AM
AH64ID's Avatar
If your stock and it's not working properly you will get a code for a solenoid fault.
Old Oct 12, 2011 | 10:53 AM
1buck4me's Avatar
It's possible.
how do i fix this or test it to make sure. Or is this something I deal with?
Old Oct 12, 2011 | 11:08 AM
AH64ID's Avatar
Only way to fix it is with a different turbo, but you can reduce the effects with a working command valve.
Old Oct 12, 2011 | 03:17 PM
1buck4me's Avatar
thank you. I orderd the new command valve yesterday. it should be in this week I hope
60valves
Apr 16, 2015 07:32 AM
lspindl3
Jul 9, 2013 10:44 PM
John Rodriguez
Sep 28, 2005 11:46 AM
Jim Lane
Sep 16, 2005 09:39 PM
C Pierce
Mar 21, 2005 08:41 AM
