So where is the injector pump
Old Nov 21, 2003 | 05:09 PM
Slice's Avatar
O4 2500 do not see any type of pump on the frame between the fuel tank and fuel filter. Any ideas guys.
Old Nov 21, 2003 | 05:56 PM
MikeyB's Avatar
Re:So where is the injector pump
If you're referring to the lift pump it's mounted to the fuel filter housing. It's on the backside of the housing towards the firewall.
The injector pump is mounted on the driver side of the engine.
MikeyB
Old Nov 21, 2003 | 06:07 PM
Shovelhead's Avatar
Administrator / Scooter Bum
The 03s and up use a pump to pressurize a common rail, then use solenoid fired injectors to spray fuel into the chambers.
Old Nov 22, 2003 | 11:58 AM
pwabbott's Avatar
FUEL INJECTION PUMP
DESCRIPTION
A Robert Bosch high-pressure fuel injection pump
is used. The pump is attached to the back of the timing
gear cover at the left side of the engine.
FUEL TRANSFER PUMP
DESCRIPTION
The fuel transfer pump (fuel lift pump) is attached
to the rear of the fuel filter/water separator housing.
The 12–volt electric pump is operated and controlled
by the Engine Control Module (ECM).
8)
Old Nov 22, 2003 | 04:41 PM
Slice's Avatar
thanks all for the answers. clears thigs up a bit
gablekevin
Sep 19, 2006 12:12 AM
jbevly
Sep 5, 2006 03:59 PM
loveturbowine
Jul 26, 2005 05:50 PM
Puke
May 22, 2003 12:18 AM
