So now my transfer case is leaking
Changed the fluid in my transfer case on my 06. Filled it with the ATF+4 like the book says. I also replaced the Rear u joints (one was bad.)
Now I have ATF+4 leaking out the rear seal onto the u joint which is slinging it up onto the bottom of the bed .Anyone replace that rear seal in the transfer case. Maybe I damaged it putting the driveline back in?
Found this thread. couldn't pull up pics.
https://www.dieseltruckresource.com/...fer+case+leaks
I had to cut the u-joints out. sounds like maybe the yoke has a rubber seal in it that I may have damaged? anyone have any info on this?
Stupid question, but are your certain you didn't overfill the case? I had a Toyota case start leaking at the rear output seal and it was because I accidentally filled the case twice LOL
Naw, just topped it until it started running out the filler hole. Boy that ATF+4 is nasty smelling stuff. I can smell it from inside the cab at 60mph with all the windows rolled up.
Hope so, that would be an easy fix. Trying to fifure out if there is some rubber seal in the yoke I may have damaged by cutting the u joint out. Ill go clean up the yoke and see if I can tell where it is leaking. very possible about the freeze plug as the u joint is slinging oil every where.
