leaking transfer case
Old Feb 28, 2005 | 09:12 AM
snakefarmer's Avatar
I was wondering what fluid to use on the transfer case? I have a rear seal slinging oil everywhere. Getting ready to put a new cerametalic clutch in, since I have to pull it out anyway might as well drain & fill the tranny & transfer case. thx in advance
Old Feb 28, 2005 | 11:36 AM
silver_goat's Avatar
Xfer Case calls for ATF+4. I believe its capacity is 2.5 qts.
Old Feb 28, 2005 | 12:46 PM
AZ42girl's Avatar
The ATF+4 is a dealer only part!!! and you are supposed to change the oil every 24000 thousand miles. Keep records. If you don't have they will not even look at your truck. At least that is what happened to me.
Old Mar 1, 2005 | 08:44 AM
Buzzer's Avatar
You can use any ATF such as Dex 3 in the transfer case. Doesn't matter.
Old Mar 1, 2005 | 10:33 AM
Never heard this one before. Got a source for that info? (no flame intended.) If anything will work I do not want to keep using that high priced atf+4 if I do not have to.
Old Mar 1, 2005 | 07:54 PM
RamDan03's Avatar
My rear extension housing on the transfer case is shot and started leaking too.
Fluid specified in the shop manual is ATF+4. For the most part it is a dealer only item, however there are a few other options.
Valvoline Max Life ATF can be used:
http://www.valvoline.com/pages/produ....asp?product=6
or you could use Redline Synthetic ATF or Amsoil.
Personally I wouldn't really worry too much about purchasing ATF+4 from the dealer since it is only going in the transfer case. If I had an automatic transmission this might be a different story. The transfer case seems pretty beefy and is not a DC specific item. It is made by New Venture Gear.
http://www.newventuregear.com/tcases.html
Depending on which model 4x4 you have, you will have either the NV271 or NV273 (Electric Switch on dash)
Just my .02
Old Mar 1, 2005 | 08:21 PM
Buzzer's Avatar
silver_goat - The same transfer case is in most 4X4vehicles (New Venture). Each auto manufacturer specifies their own fluid. You can look at a chevy and find the same case specifing Dex ATF. Its nothing more then gears and a chain. To the transfer case ATF is ATF. I personally use Redline but thats me. Others can use whatever ATF they perfer.
Old Mar 2, 2005 | 06:06 AM
JohnnyH's Avatar
John....Do you use C+ATF from Redline. That is what I plan on putting in the transfer case soon. Also, do you know of a place closer than Lindenhurst to get Redline.
Thanks
John
Old Mar 2, 2005 | 06:25 AM
Buzzer's Avatar
Thanks
John
John..the answer is yes because I need it for the tranny anyway, but as I stated any synthetic ATF will do the job. Try www.myoilshop.com prices are good and I've ordered from them before. Very prompt.
Old Mar 2, 2005 | 09:17 AM
I agree with you that most auto makers push their own fluids, for obvious reasons. I think that ATF+4 is probably not the best choice for the xfer case but DC sets the spec. and using anything else can cause problems if you need warranty work later. I would have thought that something like 75-90 diff lube would be better because of the type of gears in the case.
I guess my point was to say you can just use anything is just a bit to broad. Any ATF is probably ok.
Goat
Old Mar 2, 2005 | 09:38 AM
Buzzer's Avatar
Goat
Like I said in my post any ATF would be OK. Not just any oil. Also there is no way they could void a transfer case warrenty for using an ATF other then ATF+4. They could try but I doubt it would hold up. That is if they could even tell the difference.
primepedaler
Oct 19, 2005 06:59 PM
low c1500
Jun 28, 2005 02:35 AM
NOTSTK
Oct 29, 2003 08:56 PM
