Transfer case leaking
Old Oct 15, 2003 | 08:21 PM
NOTSTK's Avatar
Got a 98 4x4, transfer case is leaking at the rear seal and a little around the connection between the 5spd and the transfer case, can you buy the rear seal and I imagine it isn't hard to change right ? :-
Old Oct 15, 2003 | 09:05 PM
Eat Beef's Avatar
From: Alberta Foothills - Power to grow with 6 in a row - XLR8
Re:Transfer case leaking
NOTSTK,
Yes and yes.
Old Oct 15, 2003 | 09:07 PM
NOTSTK's Avatar
Where and how much, yes is hard to change or easy ? Imagine is just remove old and drive in a new one right ?
Old Oct 15, 2003 | 09:19 PM
Eat Beef's Avatar
NOTSTK,
I can't remember the price; not much though. You have to remove the skid plate and cross member, then drop your drive shafts, then remove t-case from tranny, then remove the seal and replace, then seal t-case and tranny connection with silicone, then reconnect everything that came off. Good luck.
Andy
Old Oct 15, 2003 | 09:36 PM
Haulin_in_Dixie's Avatar
Gotta disagree with one thing you said. The transmission has a rear seal and the transfer case has a front seal, there is no sealing necessary between the two housings. Better not to seal it so that when a leak occurs you can see it. So just bolt up the transfer case to the transmission, no sealant necessary or desired.
Old Oct 16, 2003 | 08:12 PM
NOTSTK's Avatar
Sorry my fault, it is leaking at the rear of the transmission, but still a little around the mounting point of the transfercase.
Old Oct 29, 2003 | 08:56 PM
vernl's Avatar
On my 96 i had several minor oil leaks including this one, once i had the new seals installed, i added the apprpraite stop leak to each component and had 400000 leak freem miles after that
primepedaler
Oct 19, 2005 06:59 PM
low c1500
Jun 28, 2005 02:35 AM
snakefarmer
Mar 2, 2005 09:38 AM
