Smoke on startup. Should I even worry about it?
Old Apr 27, 2010 | 04:24 PM
sdaly's Avatar
Like several owners here, I recently started getting the white smoke on startup only after the truck has been sitting for 8 hours or more usually. It clears pretty quickly. The greatest amount of smoke is right when it starts then it tapers off and by about 20 seconds later its just about gone. By the time I drive off its completely gone. I've changed my fuel filter, I've run a couple of tanks of PS through it, haven't tried 2 stroke oil yet, and I'm checking my oil level at every fillup to make sure its not making oil. So, I'm pretty sure its an injector with a slow leak while the truck is off.
So my question is...should I even worry about diagnosing and repairing the offending injector(s) or just let it go? Is there any problem with letting it go (other than it might worsen over time)?
Old Apr 27, 2010 | 09:54 PM
Spooler's Avatar
I would have a return flow test done on them just to be sure you O.K. A bad injector can melt a piston.
Common
May 23, 2007 07:26 AM
DennisT
May 11, 2007 08:58 PM
flyfsh70
Oct 5, 2006 02:40 PM
kens_isb
24
Feb 18, 2006 07:16 PM
Badd Dogg Guy19
35
Jun 9, 2005 08:42 PM
