Should I worry about the headgasket with the following...?
Old May 22, 2007 | 04:24 PM
Common's Avatar
75 HP DDP's
10 Plate Stock Position
AFE Stage 1
35 PSI
And will I need a new turbo right now with the stuff listed?
Sorry for so many topics, but I'm learning....
Old May 22, 2007 | 04:53 PM
stuckey200224's Avatar
Originally Posted by Digital Bullet
75 HP DDP's
AFE Stage 1
35 PSI
you should be ok but every truck is diff i beat on my stock hg with what is in my sig and i can hit 60lbs when ever i want bot my buddys truck blew at 40lbs with same setup and stock turbo
Old May 22, 2007 | 06:07 PM
displacedtexan's Avatar
No, but I bet you will
I'd look at timing and a GSK ans well as pushing the plate forward before injectors. You should still be fine with the stock turbo if you don't tow HEAVY.
Old May 22, 2007 | 06:56 PM
robert chilton's Avatar
He may be alright towing. I just installed a 913 pump and managed to pull 21k gross without problems. I still need to fine tune the GSK and I also blew the head gasket on the test drive. Probably my fault for getting the timing wrong the first time. Dont bar the motor backwards when the timings being set. Thinks that it was around 60 degrees
Old May 22, 2007 | 10:57 PM
How was the low end with 60*?
Old May 23, 2007 | 12:23 AM
Ph4tty's Avatar
Just get a set of studs next so you can quit worrying about the HG
Coming from the guy who has no studs and worries about his hg- maybe I should give myself the same advice
Old May 23, 2007 | 07:26 AM
Wouldnt start but it smoked like a pulling truck trying to get going. There was white smoke so thick that it looked like a fog bank rolling in!!! Finally figured out what was wrong, fixed, and then test driven. Came back and saw smoke out the down draft tube. You guessed it, blown head gasket.
Common
Feb 20, 2008 04:49 PM
DennisT
May 11, 2007 08:58 PM
flyfsh70
Oct 5, 2006 02:40 PM
kens_isb
24
Feb 18, 2006 07:16 PM
Badd Dogg Guy19
35
Jun 9, 2005 08:42 PM
