smoke and low power
Old Jul 10, 2017 | 03:10 PM
joem's Avatar
smoke and low power
A friend picked up a 03' quad cab 6 speed with 285K on it for $9K everything checks out good, normal blow by for such mileage and zero oil usage. truck looks and runs great except it drives power wise like 1994 160 HP truck and smokes heavily- could not here the turbo much either. No codes- whatcha all think?
Old Jul 11, 2017 | 02:54 PM
FMB's Avatar
FMB
Originally Posted by joem
. . . smokes heavily- could not here the turbo much either.
Cheap and easy diagnostic? I would pull a boot off the turbo and see if it spins freely by hand. Not hearing the turbo whine, as well as the black smoke and no power, are good clues the turbo isn't working as expected.
Old Jul 12, 2017 | 09:02 AM
pmtg's Avatar
wastegate stuck open
Old Jul 12, 2017 | 02:12 PM
StealthDiesel's Avatar
What are the boost readings? What are the low side and high side fuel pressure readings?
If the truck doesn't have those gauges, that's the 1st step.
Old Jul 12, 2017 | 09:59 PM
joem's Avatar
doesn't have gauges, hooked my OBD up to it, but no rail or boost readings. Will explore turbo issues as mentioned, waste gate and the berring slop
Old Jul 19, 2017 | 09:31 PM
boughtadodge's Avatar
My 2004 ran like that previous owner put the wrong injectors in it.
MontanaSteve
Feb 6, 2017 06:15 PM
90dodge
Jun 12, 2008 03:08 PM
JIMCTD
17
Aug 8, 2006 04:55 PM
Breck-Ram2500
Jun 2, 2006 07:47 PM
spitzair
Jan 24, 2006 03:42 PM
