A Simple High Idle Question
Old Sep 29, 2007 | 03:38 PM
Graphite 6's Avatar
Howdy, while reading wagonfixns, mod for the high idle feature, he says ECU block B is the one we plug the pigtail into, my question is each block has two sets of pin blocks w/ the allen head screw in the middle. Soooo do you count ALL the way across? or count the block on the left down to the bottom then move to the right side of the block for Pin # 22? Please, Thanks.
Old Sep 29, 2007 | 07:29 PM
Mopeman's Avatar
If you look real hard, you can see that the connector is numbered. #1 is on the upper left hand side of the connector as you look at the outside/backside. There are only 10 pins in a row, so #22 is in the thrid row, second pin hole in. Use a paper clip to push out the blue plug in the connector, then the new pin should just lock into the connector with a click. Also, the "B" connetor is the one furthest to the rear.
Old Sep 29, 2007 | 07:57 PM
scootertrash35's Avatar
if you need it i'll take a pic of mine
90 power ram
Mar 15, 2011 09:37 AM
kicker210
Dec 2, 2009 08:23 AM
cwrhnr
May 19, 2009 05:18 PM
jmccart
Jun 12, 2007 02:12 PM
