Shifting Problems need help
Old Nov 3, 2010 | 05:12 PM
pieter_2004's Avatar
Angry NV5600 Shifting Problems need help
I have a 2004.5, 6 speed NV5600, Southben 1947 Con Fe clutch 135,000 miles. I am having issues putting my truck in gear. When i press on the clutch i have to find a gear that will work then go to second gear to take off. Once it starts shifting it works great. When i stop at a stop light it has the same problem but not every time. I installed the southben heavy duty clutch assembly about 2 years ago, i hope that is the problem but not for sure. Please help.
Old Nov 6, 2010 | 01:45 AM
notw's Avatar
Welcome. Did you change the throw-out bearing when you installed the new clutch?
Old Nov 6, 2010 | 07:03 AM
I do not believe so unless it came with the sb clutch kit. I changed my oil yesterday so I can do the cheapest solution first. The reason I even changed it is because I had my oil changed 2 months ago and the wrong oil was put in.
Old Nov 6, 2010 | 11:17 AM
tryNto's Avatar
How did it shift before the 1st oil change?
Old Nov 6, 2010 | 04:55 PM
It shifted perfectly fine as far as far as I remember I have had it back for 2 months. Didn't have it for 6 months!
Old Nov 6, 2010 | 07:03 PM
Adaminak's Avatar
What oil was put in that was incorrect? How many miles in those two months? Did you tow anything or drive the truck hard?
The NV5600 is pretty particular about fluids, and the right oil will make all the difference in the world. Changing from factory to Redline MTL made mine shift much, much easier, and even reduced the number of flubbed 4-5 shifts.
Old Nov 6, 2010 | 10:04 PM
Well 75 85 synthetic and around 3000 miles or so. I haven't pulled anything during that time just gunned it a few times because it was out of commission for a while. No burnouts or racing.
DJ Turbo.
Oct 13, 2011 09:11 PM
Silver 002
Sep 8, 2008 09:23 PM
Brendan
Oct 17, 2007 11:12 AM
efrantz
Jan 8, 2006 08:44 PM
98 Ram 24V
Dec 24, 2005 10:19 AM
