Need help... Built Tranny not shifting
Well the pickup in my sig is the one that i am having issues with. The tranny shifts just right under normal driving conditions but as soon as i run WOT and come to a stop and start to accelerate it wont shift out of first. The only way i can get it to shift right is to shut my pickup off and sit there a min or two then when i start it and drive with light normal throttle it will shift no problem but as soon as i run WOT the next time through the gears the same problem arises. While running WOT it hits every shift just right. Other info....Fluid is right on-- ok, Tranny Temp is normal, The problem happens whether or not the smarty is on or with stock programing. No changes recently. The Mp-8 is still hooked up but ill try it without here later. Im guessing its a computer thing since it works fine after you shut it down. Oh ya no codes... Anyone with an idea?
luke03cr
Jul 1, 2011 03:56 PM
Brendan
Oct 17, 2007 11:12 AM
stevenknapp
27
Jul 10, 2004 01:11 AM
