Seafoam
Old Nov 17, 2009 | 06:14 PM
HOD-ISB's Avatar
Originally Posted by DirtEater
Where does it say alcohol?
IPA is the common abbreviation for isopropyl alcohol or isoproponal which ever you prefer to call it. JFYI isopropanol is a misnomer.
Old Nov 17, 2009 | 06:19 PM
HOD-ISB's Avatar
Originally Posted by megacabdad
MSDS: Seafoam contains three (3) ingredients.
Pale Oil
Naptha (solvent)
IPA (aka Isopropanol)
Here's some reading about the three.
http://www.seafoamsales.com/consumer...mation/16.html
http://encyclopedia2.thefreedictionary.com/Naptha
http://www.dow.com/productsafety/finder/iso.htm
Maybe in a mechanical diesel engine, it'd be fine to use.
HPCR'S have enough problems with injectors without solvents and alcohol being used.
Much better post than mine.
Old Nov 17, 2009 | 07:48 PM
FirstCTD's Avatar
Thanks for the info guys! The MSDS does not lie. I won't be putting any more in my CTD. I will run half the tank out and dilute it down with more fuel. I may use some meaner cleaner stuff or 2 stroke TCW-3. I'm glad I asked because in a gasser seafoam will work wonders. I am glad I found this forum. It has already helped me out a lot.
Old Nov 17, 2009 | 08:10 PM
purduepurdy's Avatar
Agreed on the gassers, I "sprayed for bugs" with seafoam a few times and it did a real good job cleaning out my carb. We used to use it in a few 7.3 Powerstrokes and it worked well. I use stanadyne lubricity formula in my 5.9 and have had good results. Just another suggestion.
Diesel Power Mag just did a test with a few additives. They don't get alot of respect on here, but their magazine does make for good toilet reading.
http://www.dieselpowermag.com/tech/f...est/index.html
Old Nov 18, 2009 | 12:14 PM
bonus's Avatar
Seafoam site does not list it's contents, but this stuff really cleans well. Like a gasser engine spraying a fine mist of water in the intake to clean up carbon.
Pls post link to any study done on the harmful effects of seafoam on 3rd gen fuel systems, I would like to readup.
One of the chevy sites had the lubricity study done on ULSD and it ended up on TDR. The test showed all the imposter snake oil additives that claimed lubricity but actually lowered it. Was a good read, makes you think twice about using MMO in your tank!
tsmay51
Apr 2, 2006 06:33 AM
triton0708
Mar 22, 2006 07:11 PM
coobie
Feb 11, 2006 01:43 PM
coobie
Feb 9, 2006 07:17 PM
Ph4tty
Dec 1, 2005 04:00 PM
