Fuel filter
Old Nov 16, 2009 | 01:43 PM
04 Diesel's Avatar
Fuel filter
Will a Mopar fuel filter from a 2007 CTD fit in 2004 CTD? Are they the same?
Old Nov 16, 2009 | 02:31 PM
92'1stGen's Avatar
As long as both trucks are 5.9's and not 6.7's, than yes, they'll fit. But I wouldn't use a Mopar filter though, they only filter to 10 microns absolute. 10 microns is far from the proper filtration rating that a common rail injection system needs. 2 microns is the best, but 5 is a whole lot better than 10. If you want a better filter, go buy a Baldwin PF7977. They filter to 5 microns absolute, and they'll fit in the stock filter housing.
Old Nov 16, 2009 | 04:20 PM
04 Diesel's Avatar
Do you know what micron the fuel filters are from Genos garage?
Old Nov 16, 2009 | 05:17 PM
HOD-ISB's Avatar
They offer the standard (10 mic) and the premium (7 mic). Get the premium, or even better get a Baldwin (5 mic) somewhere else.
Old Nov 16, 2009 | 10:17 PM
92'1stGen's Avatar
They only offer the Fleetguard FS19856, which has a rating of 7 microns. They used to sell the Mopar and Fleetguard 10 micron filters, but recently they stopped stocking them.
Old Nov 17, 2009 | 07:37 AM
bansh-eman's Avatar
Where are you guys buying the Baldwin?
Old Nov 17, 2009 | 09:37 AM
Dr.Dizzle's Avatar
Hi bansh-eman !
Check out the dealer locator on Baldwins' website.http://www.baldwinfilter.com
Old Nov 17, 2009 | 10:34 AM
92'1stGen's Avatar
I buy them from here: http://www.craigsparts.net/craigspar...l_Filters.html His price is the cheapest I have found, but shipping is around $8. Compared to Associated diesel who charges $13.xx for the filter and $6.00 for shipping, it's right in the ball park. I'll usually buy two at a time since I change them every 7500 miles.
Old Nov 17, 2009 | 10:49 AM
BLACKBEAR's Avatar
Originally Posted by Dr.Dizzle
Hi bansh-eman !
Where can I find the micro on the filters ? I went to the web site you posted but could not find out there micro !
Old Nov 17, 2009 | 11:31 AM
AH64ID's Avatar
Mopar/Fleetguard is phasing out the 10um filter. It is no longer speced for any engine.
The Baldwin is the best thou.
I received it thru several emails with Baldwin. Its 5um absolute.
Old Nov 17, 2009 | 11:38 AM
MikeyB's Avatar
On your next trip through Tomball stop by Performance Truck Products on FM 2978, located about mile north of FM 2920. They sell the Baldwins for a little over $12.
MikeyB
Crude dude's Avatar
Is there a performance difference between a 10 micron fuel filter and a 5 micron filter? Seems like they would be restricted or need to be changed more often. I dont know so i thought Id ask.
Old Nov 17, 2009 | 11:53 AM
Dr.Dizzle's Avatar
You may not find this information on their website. I made contact (by phone) with Baldwins' technical service department with questions in regards to their fuel and oil filtration products a few months back. The representative mentioned this fuel filter is rated at 2 mic (nominal) and 5 micron (absolute) at 98 percent efficiency.
The subject of fuel filtration has been researched extensively by forum member AH64ID, as a search on the subject will clearly demonstate his findings.
Old Nov 17, 2009 | 12:11 PM
AH64ID's Avatar
I currently have 29K miles on the filters in my truck. That is with only about a .5psi change from new at WOT. That a 20um, 5um, and 2um absolute filter setup... So no you won't have an issue running 5um. In fact the current OE filter is 7um and they are developing a 5um filter. With a rail that runs at 23K psi it is imperative to have clean fuel.
Old Nov 17, 2009 | 12:40 PM
OCMerrill's Avatar
Baldwin PF7977 @ Amazon for $13.75 if that helps. I purchased two yesterday.
