Seafoam
Old Nov 16, 2009 | 08:55 AM
FirstCTD's Avatar
Seafoam
Guys I am new to running a diesel so I was looking for a good fuel system/injector cleaner. I have had very good results with seafoam in my gasser engines so I recently put it in my CTD and WOW! It made a very big difference in the noise level in my engine. I have not finished the tank yet, so I don't know if it will continue to sound this quiet after its gone. My question is this, is there anything else I can run that is more economical with similar or better results cause I love my baby! Thanks
Old Nov 16, 2009 | 09:32 AM
bansh-eman's Avatar
I didn't think you were supposed to run seafoam in a diesel? Anyone know if that's true?
Old Nov 16, 2009 | 09:35 AM
cincydiesel's Avatar
Its made for both Diesel and Gas engines.. I generally run Power Service about every 1,000 miles. Dont know much about Seafoam
Old Nov 16, 2009 | 10:10 AM
tesla440's Avatar
When I had fuel going through my stock fuel filter housing, when I change the filter I would clean out the housing & put seafoam in it. Close everything up & fog out the back yard starting it up. It did a good job keeping the injectors clean.
Old Nov 16, 2009 | 01:48 PM
bonus's Avatar
Sea Foam is good stuff. just follow the instructions and you are set.
Old Nov 16, 2009 | 02:52 PM
CoastalDav's Avatar
Never heard of Sea Foam, got plenty of that about 4 miles to east of here.
Will look it up. Since you guys like it I might put it in the Durango. Use two-stroke TC3 in the Dodge.
Welcome to the forum. When you get time fill out your signature, see USer
CP.
Dave
Old Nov 16, 2009 | 03:22 PM
FunFinder5's Avatar
I use Wal-Mart 2-cycle oil TC3 and buy it by the gallon. .5-1oz per gallon (generally 16 oz to a 20 gallon fill up). Quiets things down nicely.
I also mix in filtered WMO every now and then instead of the TC3 2-cycle oil. I'm currently running a 25% blend right now of WMO, no difference.
Old Nov 16, 2009 | 03:46 PM
FirstCTD's Avatar
You can run seafoam in anything! my ATV is the only thing that i have found that does not like it. I was just wondering if there was a fuel additive that worked as well that was more economical. Seafoam is up to 9 bucks a can now!
Old Nov 16, 2009 | 04:13 PM
megacabdad's Avatar
FirstCTD,
Read through THIS.
It may change your mind on Seafoam use in your truck.
Old Nov 16, 2009 | 05:11 PM
HOD-ISB's Avatar
Originally Posted by megacabdad
FirstCTD,
Read through THIS.
You beat me too it lol ! Seafoam and anything else containing alcohol is a huge no no for these trucks. On a side note some of the other fuel additives actually contain acetone as a cleaning agent and is even worse than the alcohol. Water contamination is one of the leading causes of injector failure in the 3rd gens. So all emulsifiers are a huge no no because they almost completely undermine the fuel filters water separating ability. Not to mention totally wrecking the lubricating quality of the fuel. If you want to clean your injectors/combustion chambers the safe way set the truck close to stock power levels, hook up to something really hard to pull, and work the truck pretty good for an extended period.
Old Nov 16, 2009 | 08:58 PM
FirstCTD's Avatar
Seafoam is suppose to be a 100% petrolium product so i dont know where the alcohol would come from. i will do some more research on it. i will call the manufacturer
Old Nov 17, 2009 | 02:32 PM
bonus's Avatar
LOL, seafoam is 100% petrol based. NO Alcohol.
http://www.seafoamsales.com/faqs/4-d...el-engine.html
Also, if you use Two Stoke oil, dont go past 22.5 ounces. That works out to around 200-1 in 35 gallons.
I run the TC3 outboard oil, injectors sound perfect. no ticking.
32 ounces to a quart, to run any more then this is overkill.
Old Nov 17, 2009 | 04:16 PM
HOD-ISB's Avatar
Yea seafoam is 100% petrol based product. The three ingredients are 1. Pale Oil, 2. Naphtha, and last but not least 3. IPA (Isopropyl Alcohol) otherwise known as rubbing alcohol
So in summary you have a lubricant, a solvent, and an emulsifier. Bad news HPCR.
Old Nov 17, 2009 | 05:09 PM
DirtEater's Avatar
Where does it say alcohol?
Old Nov 17, 2009 | 06:14 PM
megacabdad's Avatar
MSDS: Seafoam contains three (3) ingredients.
Pale Oil
Naphtha (solvent)
IPA (aka Isopropanol)
Here's some reading about the three.
http://www.seafoamsales.com/consumer...mation/16.html
http://encyclopedia2.thefreedictionary.com/Naptha
http://www.dow.com/productsafety/finder/iso.htm
Maybe in a mechanical diesel engine, it'd be fine to use.
HPCR'S have enough problems with injectors without solvents and alcohol being used.
Last edited by megacabdad; Nov 17, 2009 at 07:20 PM. Reason: Naphtha...forgot the "h"
