Seafoam fuel additive (Update)
In follow up to yesterdays previous post on seafoam,here are my findings.I added two 16 oz. cans of the seafoam fuel additive to a full tank of fuel this morning.I drove 200 miles after the fill and have to admit my slight ticking noise I had is now gone.I guess I am sold on the seafoam as far as a injector cleaner,but will still use the stanadyne PF and primrose 405-409 additives in every tank.coobie
I would just run a new filter when you add the Sea Foam. Shouldn't hurt a thing.
Regarding the MMO, I add it to the fuel tank at a ratio of 4 oz. to 10 gals. of fuel. I do not put it in the fuel bowl, along with the filter.
You want to get as much Sea Foam into the filter bowl, as possible, so you have as pure a dose of Sea Foam running through the injectors. Adding the MMO to the fuel filter bowl along with the SF would dilute the SF. The rest, you can put into the fuel tank, or run another fuel bowl dose.
Joe F.(Buffalo)
Joe F.(Buffalo)
Originally Posted by torquefan
I've never seen this Seafoam anywhere. Where does one find it? Maybe we just don't have it up here.
If you run sea foam in the fuel tank the effects are negligable compared to putting it in concentrated. It was reccomended to me to run the seafoam when you do the filter change and use it to fill the filter housing rather than diesel. In the second generation the canister will hold a full can plus of it. In a gasser engine you pull a vaccume line and stick the line in the can and you will be amazed at the results. Just make sure you give the throttle a little extra boost while your running it.
gasser76
Feb 7, 2011 09:37 AM
